is there a fix for the wind noise on the rear pop outs on an extended cab and does everyones doors creak with the body flex or is it just mine. thanks guys, any thoughts appreciated. (2005 sierra sle ext.cab)
my truck creeks quite a bit ..not sure if it is from the windows or the plastic i only can hear it when the raido is off so it dosent really bother me ..
and only happens when the truck is not on flat pavment..![]()
Ryan
2002 Jeep Wrangler Sport 4x4 (the Yellow Jacket)
4inch suspension 3inch body
Straight 6 (383 Stroker within a year)
36inch SuperSwamper TSL.
105,000
Detroit Loccers
Daily Driver Weekend Wheeler
much more...
2004 Sierra crew cab, 2wd, 5.3 V8
2inch Daystar Leveling kit
single dumped Flowmaster 40 sieries exaust(removed)
Mb Blitz Chrome wheels
Leer Bed Cover(for sale)
50k miles
I get quite a bit of creaking on my drivers side door panel. It's mainly the housing of my window/door/mirror control panel. It drives me nuts, so yesterday I bought some thin, stick-on felt pads to see if I can stick them between the panels that are rubbing together. I'll let ya know if it works once I try it.
Matt
Hallsville, TX
2005 Silverado 1500 LS Crew Cab 5.3L 2WD
K&N FIPK II
Magnaflow Exhaust
Hypertech Max Energy Programmer
Suspension Leveling Kit
Putco Element Window Visors
Carriage Works Billet Grille
TruXedo TruXport Tonneau Cover
just the plastic creaking. very normal
2006 Chevy Silverado 1500 Z71 4x4
33" Nitto Mud Grapplers
20" Moto Metal 951 Black wheels
K&N Cold air intake
I have a good bit of creaking, way too much in my opinion.. ('07 NBS Silverado)
Today, I tried spraying silicone on any and every rubber seal around the doors. It reduced the noise alot, but I'm thinking this will only be a temporary fix. Give it a try though.
Any suggestions for conditioner/rejuvenater on these seals?
I finally fixed the creaking in my plastic door panel. It was being caused by the housing of my window/door lock control panel on the driver side. I took it somewhat apart and stuck some small felt pads that I bought at Wal-Mart (88 cents) every place it looked like plastic was rubbing on plastic. It worked! If your squeaking is caused by plastic-on-plastic, maybe you could try it.
Matt
Hallsville, TX
K&N FIPK II
Magnaflow Exhaust
Bookmarks
