GM Truck Club
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Quote Originally Posted by stinger44 View Post
    Hi, I'm new to the forum and was wondering if you had to replace the tweeters in your truck as well. I have the bose system in a 2004 Silverado and want to replace the tweeters but not sure how to take the plastic molding off above the dash along the window.
    I would appreciate any help.
    Thanks
    The pillars just have tabs and snap off. I've never just replaced the tweeters but they run at a weird ohm load. So even if you replaced the tweeter with an aftermarket one it would sound crappy considering most speakers run at 4 ohm. The bose system really is a crappy system. People just like them because they sound better than the standard stock system considering their a bit bassy. So reall the only way to get a decent sound out of your front speakers is to either buy the tweeters from the factory or bypass the amp, add new aftermarket speakers and replace the deck or add an amp to power them. Bose is a huge rip off and their not that great. They run em at a weird ohm load so you'll pay the rediculous amount of money for a new tweeter. If you did replace the tweeters with the bose ones your other speakers are soon to follow. Much better and cheaper alternative to add an aftermarket system. If you actually took the speakers out and looked at then you'd realize that their just cheap paper coned speakers with a crappy amp. So basically what im sayin is if it were me i would spend the money to bypass the bose completely and add some good aftermarket speakers and also replace th deck or add a 4 channel. That's my opinion
  2. #22
    Sr. Engineer Aeropagus's Avatar
    Jan 2005
    New Mexico
    great review, two thumbs way up on this writeup.
    John ~ New Mexico ~ It's all about the bowtie!
    2007 GMC Envoy & 2010 GMC Sierra
  3. #23
    Master Mechanic Jimmeh's Avatar
    Apr 2009
    Columbia Falls, Montana, United States
    Figured I'd add something to this for those of us with the manual locks and windows.
    The removal of the lock itself is the same (labeled B in the OP's picture), but taking the window crank off is a little tricky if you're not sure what to do. Underneath the crank (and under the panel itself) at the base of the crank, you will find a small "U" shaped clip that holds the crank in place. Here is a picture of said clip:
    Here is a picture of one of the two slots that the small ears on the clip will go into:
    The best advice I can give you is to crank the window down to where you can see the ears on this clip, take a flathead screw driver, and push on one of the ears until the clip releases from one side. Then, take that flathead screw driver and pry gently on the U part of the clip, and you'll then be able to pull the crank off. When it comes time to put the crank back on, PUT THE CLIP ON FIRST! Don't put it all the way on, though, just enough to where the ears are ready. Then, pop the crank back on with a little force, and the clip should set itself. It took me half an hour to figure out how to take the passenger side one off, and only about a minute or so to take the drivers side off after I figured it out. I also put a crack in my panel because I'm an idiot and didn't realize you just have to lift up on the panel (I started with my back doors, so I though you just pulled it out like the clips on it). Just take your time, and DEFINITELY read the first post.
    Also, I think all the W/T's will be the same, but we don't have the two caps on the front and back of the door, and there is one screw at the bottom front, one under the arm rest and one behind the lock.
    2005 Chevy Silverado W/T
    4X4|4.8 with some mods (has only slightly more pull than a 5.3)|Auto|4 door ex cab|Cooper Discoverer AT/3's in 285-75/17's on Helo 842's|Cooper Discover M+S 265-75/17's on Devino DV349's|Flowmaster 40 Single in Dual out with custom bent pipe from the end of the cats back|2" Procomp leveling kit|Custom made center console|Custom dyno tunes|Air Raid CAI|Air Raid Throttle Body Spacer|Apex brand topper|Kenwood Head Unit with Kenwood speakers|Painted mirrors/grille|Debadged except front emblem|Bilsteins front and rear
    Planned mods not in order
    2 inch lift|Custom front/rear bumper|hitch tire carrier|roof basket on topper, bars on cab|finish center console build|install Midland CB|Power options|Tint|Custom made raised bed in the bed of the truck|Lund LunarVisor
    Also have a 1992 Ford Ranger with a lot of stuff done to it. Currently waiting for a bit of a rebuild.
    "The only woman I'm pimping from now on is Sweet Lady Propane. And I'm tricking her out all over this town."
  4. #24
    This thread rocks. Too bad we've not see him around in a while. ... miss these good quality posts.
    Steve
    10 Chevy Traverse LT AWD
    02 Chevy Trailblazer LS (110K+ miles - loaded except for 4WD - WRECKED!)
    99 Chevy Cavalier LS (105K+ miles - commuter car)
    78 Chevy Suburban Silverado (454, 3/4 ton)
    62 GMC 3/4 ton Pickup (350 police interceptor)
    Remember: Search Before Posting | Fill out Your Profile & Signature
    * I've been saying for years that I was going to change my username, and I finally did.
Similar Threads
  1. 07 Silverado door panel lights flashing
    By Scott51 in forum GM Electrical Tech
    Last: 12-13-2010, 03:21 AM
  2. Remove rear door panel on 2002 tahoe
    By rgonline in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 12-20-2009, 01:09 PM
  3. 1997 silverado rear door panel
    By mytruck in forum Chevy Silverado Forum (GMC Sierra)
    Last: 08-22-2009, 11:10 PM
  4. how to remove 2008 silverdao manual door panel?
    By demoRod in forum Chevy Silverado Forum (GMC Sierra)
    Last: 01-17-2009, 10:19 PM
  5. hey all how does the door panel come off in a 2000 silverado 1500
    By Bbad in forum Audio, Video & Gadget Tech
    Last: 12-28-2008, 04:09 AM
