    Default Issues with Acceleration
    I have a 01 5.3L that has problems with acceleration. Sometimes it runs just great but then it won't accelerate and throws off random codes. I have changed the MAF, O2 sensors and inline fuel filter. Has anyone else had this problem?
    Rado2001
    What codes is it "throwing off"?
    1st time my '98 did something similar, it was the fuel pump dying. I was lucky enough to get it home, and then it wouldn't start back up. Intermittent like that can make it tricky, but one of the first things I'd do would be to put a fuel pressure gauge on it.
    2nd time I had similar symptoms on my '98 was because the battery post came loose. That weak spot in the circuit must have thrown things off, because it was fixed by tightening that connection.
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    Welcome to the site! Is your 01 5.3 a Suburban, Silverado, etc.? I have an 01 Suburban 1500 w/5.3 and there is a factory recall on the fuel delivery system and i got a new fuel pump installed at the dealer for free because of the recall.
    Darcy
    Washington State
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    I get it now Rado2001 = 2001 SilveRADO. Maybe research recalls for your year and model or talk to your dealer.
    Oct 2008
    Peoples Republic of Kalifornia
    I had an acceleration problem with my 93 Suburban, and after being told by two different dealerships, that it was within specs., I took it to an independent shop (that I later found out had been a GM Goodwrench troubleshooter), and had a complete dyno test run. The problem was a defective distributor, and the printout showed exactly what I had described. Although the dealer had jerked me around until the warranty expired, next time my first trip will be to have a dyno test. It was money well spent. Now the 454 pulls and hauls like a 454, instead of a Prius.
  1. Bad acceleration
    By 97Tahoe in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 07-22-2010, 09:53 PM
  2. Lag in Acceleration
    By 1998SilveradoGuy92 in forum GM Powertrain
    Last: 03-02-2010, 02:02 PM
  3. Clicking under acceleration??
    By bad5300 in forum General Chevy & GM Tech Questions
    Last: 05-12-2009, 07:19 AM
  4. '01 GMC Z71 acceleration stumble
    By SierraPete in forum GM Powertrain
    Last: 05-03-2009, 03:23 PM
  5. Lag in low end acceleration
    By bigwill20021 in forum GM Powertrain
    Last: 08-11-2008, 12:03 PM
