Results 1 to 6 of 6
    Jr. Apprentice tahoe freak is a glorious beacon of light
    Oct 2008
    Default Fuel Issues maybe...
    I have a 99 tahoe 4x4 350. 2 door. It's a shame they don't make em' any more I love the 2 door look. However I'm ready to take the 45 cal. to it. About a month ago, she started giving me problems. Spitting and sputtering, kicking back through the TBI. I assumed it was backpressure from the converters. It was fine for about a week, and I back to square one again. i have trouble after letting sit for a day or two. It just doesn't want to start. On a moderate temp morning it's ok. On a warm to hot day it's even better. But this morning I get up a cold front has come in and it won't start. I have changed the entire firing sys. I have changed the Intake Air Temp sensor. The only thing I can think of, is the FUEL PUMP. I thought fuel pumps just went out. No indications or signs of pressure loss. Any suggestions will be greatly appreciated. I'd hate to waste the bullet....
    Legend MrShorty has much to be proud of
    Jan 2006
    Utah
    First thing I would do if I suspected a fuel problem would be to put a fuel pressure gauge on it.
    '98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
    '92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
    "My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
    Moderator
    GaryL is a glorious beacon of light
    Mar 2006
    The Colony, Tx
    When my fuel pump started going out this last time, the truck became hard to start, but eventually would. It also started feeling real sluggish and wouldn't pull past about 4300 rpm's. The fuel pressure was showing around 55 psi, but it needs a minimum of 60 to run correctly.
    As Mr. Shorty suggested, check the fuel pressure and let us know what you find out.
    Gary
    99 K 1500 Suburban
    78 Silverado Big 10 w/factory 454
    1977 Formula
    1976 Trans Am
    1980 Honda CB900 Custom
    Oct 2008
    Default Fuel Pump maybe?
    ok, did the pressure check. I turned the key on and it jump beyond 60+. Two secs. later it drops. It's suppose to do that. The manual says to cycle the key back and forth to obtain maximum [COLOR=blue! important][COLOR=blue! important]fuel [COLOR=blue! important]pressure[/COLOR][/COLOR][/COLOR]. Each time the pressure rose above 60+, and dropped back down. How do I check the FPR?
    By the way, After cycling the key. It did it again, acted like it wouldn't start. Turned over and over and finally picked up and started. It hiccupped and coughed but it's runs. I waited a few munites and went back out to check the pressure and it's down to about 30 psi. Is that normal? Oh, and thanks for all of the help!!!!!!!!
  5. #5
    Moderator
    Mar 2006
    The Colony, Tx
    I merged these two threads so all the information is in one spot.
    Have you tried holding the throttle to the floor when you try to start it? It may be leaking gas past the FPR and causing a flooding condition. If you hold the throttle all the way down until it starts, it may make it start a little easier.
    Gary
    99 K 1500 Suburban
    1977 Formula
    1976 Trans Am
  6. #6
    Jan 2006
    Utah
    Just like you did: by testing fuel pressure. It appears that the regulator is correctly regulating the pressure. However, the fuel system should hold pressure for a time after the pump is shut off. The FPR could cause this if the diaphragm has ruptured, causing it to leak gas into the intake (and possibly flooding the engine making it hard to start). I haven't seen it myself, but reportedly you can check for this condition by looking down the throttle body past the throttle plate. If you see "clean" trails or liquid gasoline in there, then you likely have a bad FPR.
    Another reason for rapid loss of pressure like that is a bad check valve, which is part of the pump. Any leak in the fuel system, including a stuck open injector) could also cause the pressure to drop.
    Clarification: it dropped to 30 psi while the engine was "running" or after you had shut the engine off? If the fuel pressure is dropping off like that while it is running, then something is definitely wrong. clarify this point and we'll see what, if anything, it adds.
Similar Threads
  1. fuel injection issues? maybe....
    By 383man in forum Diesel & DuraMax
    Last Post: 03-04-2010, 02:59 PM
  2. fuel issues
    By jrylands in forum Powertrain
    Last Post: 05-03-2009, 12:02 AM
  3. Fuel line issues
    By MD4x4 Fireman in forum Performance & Fuel
    Last Post: 05-25-2008, 03:21 AM
  4. Fuel gauge issues.
    By BlazerJer in forum General Chevy Tech Q&A
    Last Post: 03-23-2008, 12:01 PM
  5. FUEL and ENGINE ISSUES
    By unclben7 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-16-2007, 09:56 AM
