Ok, so the time has come for me to perform my first oil change on my Suburban. I have always changed my own oil on all of my vehicles, so I know what the procedure is.
I've always used drain plug gaskets from the dealership (working in a dealership I found these always worked best), but when I called the GM dealership for a price today they told me ~$4!Is this right? This is the first GM I've owned in more than 10 years, and it's the first V8 I've ever owned. Most of my cars have been Honda/Acuras and the gasket for those are ~ $0.70 from the dealer.
So, my question is: What do you use? Do you pony up the extra cash for the dealership brand, or do you use the ribbed nylon ones from Checkers or other parts store? If you go to the parts store, what kind are you using and how is it working out for you?
i dident use one..
come to think of it i used the one on there again..
08 5.3 silverado...toyo m.t 33 12.50 18 rockstars...leveled with 2" blocks...cherrybomb catback...6k hids
Sounds like to me they are pricing a drain plug for you.. If the gasket is not to worn why replace it at this time.. The main thing I believe is dont over tighten the drain plug.
i agree with above
Here's what was on mine when I bought my '98: http://www.partsamerica.com/ProductD...pe=797&PTSet=A It fell apart when I pulled the drain plug off. Replaced with the same part. Sealed up fine, but fell apart again on the next oil change. I can't remember for sure, but I think I went with this once more before buying a nylon gasket. Nylon gasket was a lot cheaper, sealed up just fine, and has continued to seal up after each oil change just fine. IMO, these OEM rubber ones are too expensive, and they only survive one oil change. The nylon ones work just fine and are a lot cheaper.
'98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
'92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
"My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
1.10 pounds to ship it.... lol
I've changed my oil a couple times now and haven't had to replace the gasket yet. I examine it closely each time, and it's in great shape. No leaks or anything, so I think it's good. I looked on O'Reilly's site and they sell for about $4 there, but AutoZone has them for $2.
Matt
Hallsville, TX
2005 Silverado 1500 LS Crew Cab 5.3L 2WD
K&N FIPK II
Magnaflow Exhaust
Hypertech Max Energy Programmer
Suspension Leveling Kit
Putco Element Window Visors
Carriage Works Billet Grille
TruXedo TruXport Tonneau Cover
lol, i didn't know you had to change a gasket on the drain plug. I actually didn't know there was a gasket on there. I've been getting away with this without any leaks, so i dont think you really even need one.
2006 Silverado Z71 - 97,000 - totaled, RIP
2006 Silverado Z71 - 70,000 (K&N 77 Series CAI, PowerAid TBS, Magnaflow dual rear exit, 33x12.50 Mickey Thompson MTZ, Tuff Country Torsion Keys, Tuff Country Add-A-Leafs)
I'll keep my money, guns, and freedom. You keep the Change.
I buy packages of teflon drain plug gaskets from Auto Zone for about $4 (5 to a pack), been doing this for over 20 years and havent had a problem with leaks.
OEM is usually overpriced. If you have a friend with a buisiness they can sometimes get a "Jobbers" price for parts. The dealerships I deal with usually run cost plus 10% for jobbers.
Tim
2011 Silverado 1500 LT
2008 HHR LT
1999 Tacoma SR5 TRD 4X4
1993 Jeep Wrangler
1991 Toyota Rock Crawler
2009 Harley Davidson Nightrain
2004 Harley Davidson FLHT "Bagger"
2003 Glastron GXL Bowrider
I am glad you posted this reply so I am not the only one that didn't know there was one there. I've changed my own a few times now and never even noticed it. I've never had a leak so I guess its ok! I am just about to do mine today. Now that I know about it, I am sure there will be problems. It always works that way.
Bookmarks
