Ok, so I've got the 7.4l 1999 'Burban and I'm trying to get to change out that distributor. But WTH is with putting it where it is!? I can barely even see it, nevermind gett at it!
Any ideas as to how I'm supposed to get to it? Am I supposed to rent a monkey to get in there or something??
I think that may be the one time where renting a monkey will not solve your problem...
Dan
1999 GMC Sierra 2500 350 vortec
1967 Jeep M725 ambulance 230 tornado
1990 Cherokee Limited- 3 inch lift on 33's
...and every one of em has issues
If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
Welcome to chevy baby! All chevy does is put the distributor in the rear of the motor and you can't ever get to it. Its the worst design they have ever done and after a million years they never fixed it. I was changing the oil pressure swith and unlike you I could NOT see it because it was at the way back of the block. I ended up getting my neighbor that is 6'6'' to reach back there and help me get it out, yay for people with long arms. However the making the motor sag is a good idea, but its still going to be hard to get in and out of there. I have heard of people having to pull the whole block out to change it, but I don't know how fun that would be. Try the sag method and then if thats not good enough, get a cherry picker and pull that bad boy 7L out of there so you can fix it. Have you ever wondered why its way back there? Here is the answer, so it is harder to hit the distributor and move it. If you hit the little guy even a 1/4 of an inch it messes up your timing completely. It began off by clumsy people bumping the distributor while they were trying to add engine oil which threw off the timing and then the truck ran like crapso then chevy decided to put it in the back to solve this too often problem. However on fords its right up in front for the word to see! But I have personally bumped mine 10 or 20 times so I began putting a timing light in the glove box so I can fix it right away. If you wanted a distributor in the front, you bought the wrong truck, lol. Just messing not a big sacrifice to make for the quality of gm.
1996 Chevy K1500 Silverado Z71
-248000 miles
-The legendary 350 small block V8 (5.7L)
-Sound System with a 10'' kicker L5 sub and 1300W amp in a sealed box
Oooooooooooooooooooooooooooooooooooooooh!!!..
2008 Chevrolet Silverado 1500 LTZ 5.3L EC/Std Bed 4x4 Flexfuel
Full Metal Jacket Spray on Bed Liner
Black Powder coat Diamond Plate Weatherguard Tool Box
Corsa Performance Sport Exhaust System
K&N Flat Panel OEM replacement Air Filter
Bridgestone Dueler A/T Revo tires P275/55/R20
Black Reflective pinstripe and VORTEC hood lettering
Billet front bowtie
Rear Bowtie Delete
Blue strobe grille lights
Blue strobe rear window lights
Blue LED Mini Light bar in front Grille
that picture is a little close for me to see what it is, so what is it?
lol it slipped my eye, i though distributors were bigger then that
Well I would bet that they make a "Specialty" tool to reach that, you wouldn't believe some of the crap that I have bought in the past to get to stuff like that. I usually buy from Mac tools, because Snap on is way too expensive unless you have a friend at a Chevy dealer. Good luck with the problem, I was lucky enough to not have to change the distributer in my S-10 thankfully.
Bookmarks
