Results 1 to 4 of 4
    Newbie bferland is a glorious beacon of light
    Oct 2008
    Default Howling sound from 99 Suburban
    We have a 99 Suburban 2500 with a 454. Recently we have heard a "howling" noise coming from under the hood. I can only describe it as a high piched howl, if that makes any sense at all! It has no rime or reason but it speeds up and slows down with the truck, so I am leaning twards the pulley system or possibly the alternator? The brakes are fine, I think. Stopping is no problem. I have owned Chevey's all of my life and never heard a noise like that. There is no changes in the gauges when it happens and it doesn't make the noise all of the time. Any suggestions will definately help!!
    Legend MrShorty has much to be proud of
    Jan 2006
    Utah
    Does it make the noise at idle? When you say, "the noise speeds up and slows down with the truck" do you mean that it follows engine speed or vehicle speed?
    One "howl" that is normal and comes and goes is the fan. When the fan clutch warms up, it engages the fan and it howls. Sometimes when it's extra cold, the fan will be engaged until the fluid in the clutch gets warmed up a little bit. Depending on what the weather has been doing lately, the howl might be the fan.
    If it makes the noise at an idle, you might use a stethoscope and poke around at the pulleys and bearings associated with the serpentine belt. Be careful not to get anything (hair, shirt, fingers, arms, etc) wrapped up in the belt. See if you can narrow down where the noise is coming from.
    '98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
    '92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
    "My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
    Legend 95CTburb19 is a glorious beacon of light
    Apr 2007
    Umass / Newtown CT
    My sierra spent most of its life in GA and doesn't like the cold very much. The fan makes a ton of noise when I first start it in the winter time and continues to be loud until it warms up. If that isn't your problem then I think checking the alternator and the other belt driven components could give you some idea of whats going on.
    Dan
    1999 GMC Sierra 2500 350 vortec
    1967 Jeep M725 ambulance 230 tornado
    1990 Cherokee Limited- 3 inch lift on 33's
    ...and every one of em has issues
    If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
    Oct 2008
    Default Thanks!!
    Well thank you very much for your help!! We have narrowed it down to the alternator or the fan clutch.. It hasn't done it in a few days and the truck is running great as always, but it has been warmer here in AZ. The battery gauge is great as well so I see no catastrope's in the future!! Thank you again!!
Similar Threads
  1. Replies: 0
    Last Post: 04-07-2010, 04:53 PM
  2. Replies: 9
    Last Post: 09-22-2009, 10:33 AM
  3. Howling from rear end ?
    By edc in forum Powertrain
    Last Post: 09-10-2008, 01:43 PM
  4. Replies: 0
    Last Post: 04-19-2008, 11:46 PM
  5. howling rear end
    By 95CTburb19 in forum Powertrain
    Last Post: 01-24-2008, 11:13 PM
