Results 1 to 2 of 2
Thread: 1995 s-10
    Jul 2010
    Lexington, KY
    Default 1995 s-10
    All, I have an s-10 4 cyl manual 5 speed. All stock. Last week it began to act a little funny. On hard acceleration it backfires through the throttle body. Under light acceleration and idle it runs smooth as a top. I've replaced the fuel filter, air filter and checked the fuel pressure levels. All are good. Any other ideas?
    Thanks,
    Jun 2006
    Hey, a 1995 5 speed S-10 is a decent little truck with good mpg- AND PROBABLY PAID FOR- so you are doing ok.
    Your problem is fuel delivery(which you have covered a lot of), fuel mixture(vacuum leak), or ignition(dist/rotor/plugs/wires)
    I would check for vacuum leaks( hose leaking/cracked or actually off-look at brake booster hose etc).
    Then maybe eyeball your distributor/plugs/rotor /spark plug wires.
    Look at the wires at night-sometimes if they are bad you can actually see them arc-glow blue/spark etc.
    Maybe pull the plugs and look for a grunged up plug(but eyeball rotor and wires first)
    Possible you got some bad fuel(water in it) or your throttle body injectors are slightly plugged(might try some injector cleaner in gasoline-or the fuel conditioner that sucks up water-but I kinda doubt it is bad fuel unless it happened a few miles after a fill up))
    Luck
    Charlie
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
  1. 1995 k5 blazer
    By 1952 in forum General Chevy & GM Tech Questions
    Last Post: 05-18-2010, 02:54 PM
  2. 1995 Gmc 2WD 5.7L
    By Jeepguy in forum GM Powertrain
    Last Post: 04-14-2009, 04:19 PM
  3. Obd 1 1995
    By 2loud in forum General Chevy & GM Tech Questions
    Last Post: 12-21-2008, 08:13 AM
  4. 1995 Suburban
    By mrcaddy in forum General Chevy & GM Tech Questions
    Last Post: 09-30-2008, 06:48 PM
  5. Question about 1995 4WD
    By Team 35 in forum GM Powertrain
    Last Post: 03-05-2008, 11:01 AM
