Results 1 to 5 of 5
    Newbie THEEDGE714 is a glorious beacon of light
    Oct 2008
    Default Hard/No start when Cold outside
    My 1998 5.0L was having problems starting this summer and I diagnosed it down to a bad crank sensor. I was able to replace it and everything was fine. Now that it has started getting cold in Indiana, the van is having problems starting again. It either takes 10 or 15 tries and finally starts and I have to play with the throttle to keep it going, and then once it is running it is fine. Or...I crank it so much that the battery dies...
    I'm thinking of cleaning the IAC motor and also trying to borrow a scan tool to check the coolant temp and intake air temp sensors. Any other ideas???
    Thanks,
    Doug
    Legend MrShorty has much to be proud of
    Jan 2006
    Utah
    In addition, I'd check fuel pressure.
    '98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
    '92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
    "My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
    Moderator
    dwill3015 has a reputation beyond repute
    Jan 2007
    Yacolt, Washington
    How is your fuel delivery system? (pump, filter, fuel pressure relay)
    Darcy
    Washington State
    Oct 2008
    The Fuel Pump was replaced about 6 months ago and I checked the fuel pressure when I was battling a crank sensor problem about 2 weeks ago and it measured about 55psi. I think that all is OK. Its really weird...it acts like it's not getting fuel when it's cold. I read the codes today and there were none set. Turned the key on and it showed the CLT temp and Intake air temp both at about 59F, which was because it was colder outside than that, but it is a black van and it was sitting in the sun. Couldn't get it to fire consistently and wouldn't start. Pulled the CLT temp conn. off to make it think it was -40, and it finally gave more fuel and started. I know it needs new plugs because they have 100,000 miles on them. I asked the dealership to change them when they put on the Intake Manifold and they said they only changed the one plug that was fouled due to the manifold leak. The others looked fine....yeah...they didn't want to change them! Looks like it will be a fun job....
  5. #5
    Legend tlperry68 is a glorious beacon of light
    Oct 2008
    Huntington Beach, CA
    I might try the spark plugs. Also what ever electrical system you have that delivers power to the plugs. In colder weather moisture can collect on the metalic parts and start to corode them weakening your system. just a thought.
    Trevor - Huntington Beach, CA
    2007 GMC 2500 4X4
Similar Threads
  1. Help with a hard start issue...
    By alchemist1 in forum Powertrain
    Last Post: 10-25-2010, 09:45 AM
  2. 2001 1500 hard to start
    By bajahucks in forum General Chevy Tech Q&A
    Last Post: 02-13-2010, 12:24 PM
  3. 96 K1500 hard starting when engine cold
    By kcstrom in forum General Chevy Tech Q&A
    Last Post: 08-25-2009, 09:54 PM
  4. Hard shifting into gear when cold
    By Castor Troy in forum Powertrain
    Last Post: 12-08-2008, 10:17 PM
  5. Hard to start suburban
    By ftwken in forum Powertrain
    Last Post: 01-09-2008, 04:51 PM
