Results 1 to 10 of 12
    Default Engine Clatter at WOT
    I've noticed the last few times I've put the pedal to the floor (usually when passing someone), I hear a slight clatter from the engine. I changed to synthetic oil a little over 2000 miles ago, and I don't remember ever hearing it before that. My truck has about 68000 miles on it. What could be causing that clatter? Is it a problem? What can I do to fix it? Thanks!
    Matt
    Hallsville, TX
    2005 Silverado 1500 LS Crew Cab 5.3L 2WD
    K&N FIPK II
    Magnaflow Exhaust
    Hypertech Max Energy Programmer
    Suspension Leveling Kit
    Putco Element Window Visors
    Carriage Works Billet Grille
    TruXedo TruXport Tonneau Cover
    could be belt area chatter, the clutch in the ac unit or alternator
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Bumping this thread. I hadn't noticed the clatter again until yesterday. I punched the pedal to the floor from a slow, rolling stop and there was more than a slight clatter. It hauled a$$, but the noise sounded awful. Anything I can test to find out what it might be? I want to fix this. I don't like my engine making weird noises!
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    Is spark-knock like detonating? If so it could be from running low octane fuel, a dirty throttle-body, or maybe even some injector cleaner might help.
    Darcy
    Washington State
    It's like a skittering clatter...if that makes sense. I do run regular fuel, but I ran the regular fuel tune on my max energy. Maybe I'll run a can of Seafoam through the gas tank. I plan on playing around under the hood tomorrow to see if I can notice anything out of the ordinary.
    Also try putting in some octane booster and see if that helps. Maybe you got some bad gas into the tank?
    '93 Chevrolet Silverado 6.5L Turbo-diesel (Currently most reliable)
    '05 Honda Rancher 329CC (Flipped multiple times by different people)
    '72 Volkswagen Beetle 1.6L (Being rebuilt to 1641cc)
    '76 Chevrolet Scottsdale C20 350CI (My experiment!)
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    My Wife's 01 Suburban w/5.3 chatters if she does not run mid-grade fuel or better.
    Quote Originally Posted by dwill3015 View Post
    Hmm...do you think it's anything I need to be concerned about? It only does it if I really get on it, and I don't do that very often. I guess it still couldn't hurt to run some Seafoam through it. You think I should re-tune to the premium setting on my programmer and start using premium fuel?
    Question
    A month later and you are still having the problem, I would have thought you would have run a couple of tanks through by now! I have my own question that may help you! Could a faulty knock sensor cause this?
    Phil
    Happy 2 Wheeler!
    Quote Originally Posted by FireRed View Post
    Phil
    Well, I hadn't noticed the clatter again until now. Only happens when I really punch it, but I don't do that very often. Not sure if the knock sensor could be causing it or not. To be honest, I don't know what a knock sensor does
  1. engine fan
    By countryboy73703 in forum General Chevy & GM Tech Questions
    Last: 06-14-2010, 02:21 PM
  2. 76 c10 new engine
    By 76-C10Strokin in forum General Chevy & GM Tech Questions
    Last: 01-12-2010, 07:57 PM
    Last: 09-29-2009, 02:46 PM
  4. Ward's AutoWorld honors Flint Engine South 3.6-liter V-6 engine - MLive.com
    By ChevyFan in forum Chevy Traverse Forum (GMC Acadia, Buick Enclave)
    Last: 01-16-2008, 12:40 AM
