Results 1 to 2 of 2
    Sr. Mechanic DirtDog is a glorious beacon of light
    Jan 2008
    Livingston, TN
    Default Resetting oil life monitor...
    OK, I just changed the oil in my truck. I reset the Oil life monitor using the following procedure:
    1. Turned the ignition to ON (engine not running)
    2. pressed and released the gas 3 times.
    3. Message saying "CHANGE ENGINE OIL" appeared for about 2 seconds
    4. Message saying "OIL LIFE RESET" appeared for about 10 seconds.
    5. I then started the truck.
    6. Message saying 'OIL LIFE RESET" appeared again for about 5 seconds, then the DIC returned to the odometer screen.
    OK, prior to doing this, the CHANGE ENGINE OIL message had not yet come on, and my truck does not have all the DIC functions like others do. I only have odometer, trip, and engine hours. I cant see if it reset or not, did I do this right? I have read that you are supposed to turn off the ignition after pumping the gas 3 times, then turn it back on. Does that make a difference, or does the way I did it do the same thing?
    Thanks.
    Jack.
    2007 Chevrolet Silverado 1500 Classic.
    1993 Dodge Stealth 3.0L V6 - SOLD
    Live to ride, Ride to live.
    It is what it is, -N- STUFF!!!
    Legend bry2500 is a glorious beacon of light
    Oct 2008
    Gloucester, MA
    I followed the same procedure for my 02 avalanche. It did the same thing and show theoil change needed warning. after starting it. I tried it again but got the same results. I went for a ride and the next time I started the truck it was gone. Maybe the computer needs to see the odometer start to move in order to do the full reset.
    BRYAN
    "IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
    02' Avalanche 2500 Onyx Black
    8.1L Vortec
    43,000 miles
Similar Threads
  1. Oil Life Monitor Reset
    By Thunderchild in forum General Chevy Tech Q&A
    Last Post: 10-29-2009, 12:41 PM
  2. GM Oil Life Monitor System Frequently Asked Questions
    By Dr_Zero in forum General Chevy Tech Q&A
    Last Post: 05-22-2009, 01:49 AM
  3. Oil Life Monitor System Problems
    By tlperry68 in forum Powertrain
    Last Post: 12-07-2008, 12:45 AM
  4. GM Oil Life Monitor
    By Steve in forum Performance & Fuel
    Last Post: 08-18-2008, 03:29 PM
  5. Silverado oil life monitor
    By bd2200 in forum Powertrain
    Last Post: 01-12-2008, 09:10 AM
