Results 1 to 6 of 6
    Newbie Brian_4.3L_Sonoma is a glorious beacon of light
    Nov 2008
    Atlanta, Georgia
    Default Newbie needing sroodo help
    OK, Have a 94 gmc sonoma 4.3 with 214000 miles on it, CPI... I just replaced my vehicle speed sensor(VSS) on my transmission due to loss of movement in my odometer, speedometer, tripometer, no cruise either.. so i replaced it... Two days later the speedo has stopped working... As far as i can tell the odometer is till working.. Any suggestions?
    -Cox 4.3L Sonoma
    Moderator
    dwill3015 has a reputation beyond repute
    Jan 2007
    Yacolt, Washington
    Welcome to the site! Hopefuolly someone will step forward with some helpful advice for you.
    Darcy
    Washington State
    Sr. Mechanic DirtDog is a glorious beacon of light
    Jan 2008
    Livingston, TN
    Hello and welcome to the site. If your odometer is still working, then your speedometer has died. This was a fairly common problem on the S-10's and sonoma's. you need to replace your cluster. you can get them off ebay pretty cheap. Here's a link to one I just found for $69 plus shipping:
    http://cgi.ebay.com/ebaymotors/1994-...Q5fAccessories
    Hope this helps
    Jack.
    2007 Chevrolet Silverado 1500 Classic.
    1993 Dodge Stealth 3.0L V6 - SOLD
    Live to ride, Ride to live.
    It is what it is, -N- STUFF!!!
    Nov 2008
    Atlanta, Georgia
    Ok, but what made it work then die... do i have a wire gone bad
    -Cox 4.3L Sonoma
  5. #5
    Jan 2008
    Livingston, TN
    Quote Originally Posted by Brian_4.3L_Sonoma View Post
    Could be a short in the cluster, or just by some chance the cluster may have been close to death when the speed sensor went out, then after it was replaced, the cluster worked for a bit, then died.
    Jack.
  6. #6
    Nov 2008
    Atlanta, Georgia
    Default ok
    Alright new cluster.. on the wish list.. Now today my E-brake light wont shut off... i tried to get it un stuck but i had no luck? is there a possibilty that it is broke
    -Cox 4.3L Sonoma
Similar Threads
  1. needing an s-10 body
    By scrappyss in forum Chevy S10 Forum (GMC Sonoma)
    Last Post: 09-09-2009, 10:22 PM
  2. New Member Needing
    By bimmer84 in forum Member Introductions
    Last Post: 01-03-2009, 01:22 PM
  3. New guy needing some info
    By nvyseal11 in forum Powertrain
    Last Post: 10-09-2007, 07:36 PM
  4. New guy here needing help
    By big red in forum Powertrain
    Last Post: 09-11-2007, 01:01 PM
  5. New Tahoe Owner....needing answers!!!
    By NCmarine in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 07-21-2005, 09:48 PM
