Results 1 to 8 of 8
    Sr. Mechanic Big6ft6 is a glorious beacon of light
    Jul 2007
    Default If my truck had a stock oil cooler, should I put a new one in with new engine?
    Title says it all.
    Truck had OEM engine oil cooler, it was really nasty and some lines broke when I pulled it out. I put in a new engine w/o an oil cooler assembly know I could add one later if needed.
    my question is should I? Or only if I"m going to be towing and stuff at max load?
    I figured it was originally added becuase this was a 3/4 ton truck with A/C etc..but I pulled the A/C so that should help with engine temps...but how about towing?
    Legend retired2001 is a glorious beacon of light
    Nov 2006
    Canyon Lake, Texas
    Just my opinion, but I'd say yes. Heat is the transmissions worst enemy. There are "add on" coolers on the market that can really help out. My brother has had to replace his tranny recently due to a failure of the cooling lines failing inside the bottom of the radiator and dumping the fluid into the cooing system. His mechanic found this and after rebuilding the tranny, added an external cooler. Good luck!
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
    Jul 2007
    Retired2001, thanks for the quick response. The oil cooler I am referring too is the less common engine oil cooler not a transmission oil cooler. The engine oil cooler ran from a piece sandwhiched between the oil filter and the block to a small radiator up front.
    I agree, transmission oil cooler is a definite must have in my opinion too, but in this case I'm wondering about actual engine oil. Any thoughts?
    Legend ct9a is a glorious beacon of light
    Jun 2008
    Colorado
    I would say go for it. Heat isn't good for the viscosity of oil. Even so, an oil cooler couldn't hurt anything.
    Scott
    ΜΟΛΩΝ ΛΑΒΕ
    '94 Chevy Suburban K1500
    3" exhaust w/ aero turbine non-baffled muffler
    CFM Technologies TB spacer
    CB w/ 44" whip antenna
  5. #5
    Moderator
    dwill3015 has a reputation beyond repute
    Jan 2007
    Yacolt, Washington
    I am in agreement that the cooler should stay.
    Darcy
    Washington State
  6. #6
    Legend tlperry68 is a glorious beacon of light
    Oct 2008
    Huntington Beach, CA
    I would change it out as well. Those radiators are small and a change would be quick and easy.
    Trevor - Huntington Beach, CA
    2007 GMC 2500 4X4
  7. #7
    Master Mechanic CarpenterGuy is a glorious beacon of light
    Jul 2008
    Leeds, Alabama
    How do I know if i have an engine oil cooler and transmission fluid cooler?
    2006 Silverado Z71 - 97,000 - totaled, RIP
    2006 Silverado Z71 - 70,000 (K&N 77 Series CAI, PowerAid TBS, Magnaflow dual rear exit, 33x12.50 Mickey Thompson MTZ, Tuff Country Torsion Keys, Tuff Country Add-A-Leafs)
    I'll keep my money, guns, and freedom. You keep the Change.
  8. #8
    Jul 2007
    Quote Originally Posted by CarpenterGuy View Post
    Carpenter Guy,
    the engine oil cooler is a seperate small radiator in front of the normal radiator on the drivers side of your turck. If you have A/C it will be the THIRD "radiator" and smallest of the three (the A/C condensor is quite large maybe 2/3 the size of your normal radiator and the engine oil cooler is roughly 12" x 12")
    An easier way to tell might be to look and see if you have two lines coming from just above your oil filter and heading out to the front of your grille.
    Most trucks have a transmission oil cooler, but it is built in to the side of the radiator. Look for two hard lines coming into your radiator on the passenger side. On newer vehicles it may have its own "radiator" type heat exchanger as well. But on older vehicles it is inside your radiator.
Similar Threads
  1. Engine Oil Cooler
    By asanford in forum Powertrain
    Last Post: 12-13-2009, 12:11 AM
  2. Engine oil cooler lines
    By mjlatheo@cox.net in forum General Chevy Tech Q&A
    Last Post: 09-19-2009, 11:47 AM
  3. Upgrading stock transmission cooler
    By russ115 in forum Powertrain
    Last Post: 09-02-2009, 11:17 PM
  4. engine oil cooler lines
    By Graytop in forum General Chevy Tech Q&A
    Last Post: 12-25-2008, 02:55 PM
  5. Engine oil cooler lines for 99-00 GMC
    By Graytop in forum How-to Guides
    Last Post: 12-19-2008, 09:45 PM
