Thread: Twist in bed?
    Default Twist in bed?
    Hey,
    Just bought a 2004 Silverado extended cab and have noticed since I have a rear-window defroster (with the lines going across the window) that the rear left side of the pickup bed sits higher than than the right side -- this goes for all types of roads, right or left side of the road, and when the truck is sitting still. Is there any way I can attempt to correct this?
    Thanks for your ideas.
    I have never hear of the rear defroster impacting the bed that way. Hopefully someone will chime in.
    Dan
    1999 GMC Sierra 2500 350 vortec
    1967 Jeep M725 ambulance 230 tornado
    1990 Cherokee Limited- 3 inch lift on 33's
    ...and every one of em has issues
    If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
    Master Mechanic CarpenterGuy's Avatar
    Jul 2008
    Leeds, Alabama
    LOL the defroster twisting a bed. Genious
    Maybe your defroster lines are crooked? Also check your bed mounts and see if everythings tightened up and theres nothing extra inbetween the bed and chassi, other than normal mounting hardware, then take it to a body shop. You might have a twisted frame? I'm not sure if a twisted frame would do that.
    2006 Silverado Z71 - 97,000 - totaled, RIP
    2006 Silverado Z71 - 122,000 (K&N 77 Series CAI, PowerAid TBS, Magnaflow dual rear exit, 33x12.50 Mickey Thompson MTZ, Tuff Country Torsion Keys, Tuff Country Add-A-Leafs)
    1966 C10 swb stepside (Gen I 350, Turbo 400 trans, dual cyl power brakes, front discs)
    I'll keep my money, guns, and freedom. You keep the Change.
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    Do your bodylines on both sides of the box match up with the cab?
    Darcy
    Washington State
    are you saying the defroster lines are your reasoning in sayin the bed is not correct??
    i agree w dary check the lines
    has the truck been wrecked?
    Ryan
    2002 Jeep Wrangler Sport 4x4 (the Yellow Jacket)
    4inch suspension 3inch body
    Straight 6 (383 Stroker within a year)
    36inch SuperSwamper TSL.
    105,000
    Detroit Loccers
    Daily Driver Weekend Wheeler
    much more...
    2004 Sierra crew cab, 2wd, 5.3 V8
    2inch Daystar Leveling kit
    single dumped Flowmaster 40 sieries exaust(removed)
    Mb Blitz Chrome wheels
    Leer Bed Cover(for sale)
    50k miles
    :glasses:
    I think he is using the defroster lines as a "visual level" to determine that the bed might be crooked.
    Grab yourself a tape measure and check the distance between the floor and the rear fenders in various locations on both sides of the bed to compare. Also measure diagonally from the top corner to corner to make sure the bed square.
    Most shops will also check the frame fro free, being a safety issue.
    Park the truck on a flat surface and break out a construction level. Start by checking if the defroster is on the window straight. Then check along the top of the bed rails the front bed bulkhead and the tailgate. Compare the bed sides with one another and the bulkhead, tailgate and window lines with one another.
    Its not unheard of for trucks to sit a little crooked for a few reasons, they have long frames that are subject to warpage, theres a big weight difference between a fully fueled truck and one with an empty tank, and when you add a driver this makes an even bigger difference.
    When parked flat with a 1/2 tank of fuel there should be minor differences with the level, but for the most part you readings from side to side and front to back should be real close.
    Also check the bed mounts underneath, maybe a mounts broken loose or the body pucks are severly worn. Dont forget to check the cab mounts as the problem could be there.
    Legend tlperry68's Avatar
    Oct 2008
    Huntington Beach, CA
    I agree with Tim. Many beds becme tweaked at the frame over time. In fact run a measuring tape at the two (left and right ends) from the bed rail to the window striping and you will see that they ar off. Then go check a buddies turck and you will probably see the same thing.
    My 1995 F-150 did the same thing, I noticed it on almost every F150 since.
    Trevor - Huntington Beach, CA
    2007 GMC 2500 4X4
  1. new twist on stsrting problem
    By H.A. REDNECK in forum General Chevy & GM Tech Questions
    Last Post: 09-23-2008, 07:04 PM
