Results 1 to 2 of 2
    Default Problem someone help!!!!!!
    ok here it goes i noticed when i put my truck in park the button u got to push in order for the truck to shift gears gets stuck in sometimes i turn my truck off and the key dont turn all the way because the little button to shifter is stuck what could i do to fix the problem when i press the button a couple of times it comes out i have a 04 trailblazer
    The leather boot on the shift selector is quite thick. It sounds like what happens on mine: the boot slides down a little and gets caught in between the plastic trim and the shifter itself. It stops the shifter from going all the way into park, and a safety feature of the trailblazers is if the car's not in park, you can't shut the key off (inconvient when trying to get the instrument cluster bezel off, btw)
    Try pulling the boot up a little when it happens and push it further towards park and see if it slides in and clicks.
    If this doesn't work, it's probably the spring in the handle itself is misaligned or worn. There's a little screw on the front of the handle to remove it. The $15 Haynes manual on Trailblazers explains how to do it - the '02-'03 book will cover all the way up to '06.
  1. ABS problem
    By FireRed in forum Lifted & Offroad Suspension
    Last Post: 01-09-2010, 09:57 AM
  2. 96 Chevy tahoe problem fuel problem? Need help ASAP!
    By Fear58 in forum General Chevy & GM Tech Questions
    Last Post: 12-13-2009, 05:38 PM
  3. new here but have a problem
    By kjames323 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-06-2009, 07:41 PM
  4. A/C problem
    By mprodman in forum General Chevy & GM Tech Questions
    Last Post: 04-03-2009, 12:41 PM
  5. Problem with AC
    By 4runnerGuy in forum General Chevy & GM Tech Questions
    Last Post: 03-30-2009, 07:10 PM
