Results 1 to 7 of 7
Thread: Best ATF?
    Legend ct9a is a glorious beacon of light
    Jun 2008
    Colorado
    Default Best ATF?
    I'm sure this has been covered before, but I couldn't find anything. I have no idea when the last fluid/filter change was done on my burb, so logic dictates that I do one. I found out the hard way on my Dodge that their trannies don't like anything but a specific type of ATF. Do I need to worry about this with my Chevy? If not, what is the best ATF available that everyone has had success with? I'll be doing light towing for short distances, but long road trips to and from DFW, TX and back with a truck full of kids and luggage.
    Scott
    ΜΟΛΩΝ ΛΑΒΕ
    '94 Chevy Suburban K1500
    3" exhaust w/ aero turbine non-baffled muffler
    CFM Technologies TB spacer
    CB w/ 44" whip antenna
    Jr. Apprentice CoolAirVw is a glorious beacon of light
    Nov 2008
    Kansas City, MO
    Not so picky as the dodge. Dextron II or higher is fine.
    Synthetic like Mobile one is fantastic, (but expensive) but not needed for everyday use. Your towing might make it worth the cost though
    Sr. Mechanic raisor87 is a glorious beacon of light
    Jul 2008
    the nasti nati
    just dont use b&m trick shift that stuff sucks put it in my old truck and it sludged up in 3 months with no towing or crazy driving
    1998 GMC Sierra SLE- Bone stock engine, 4'' in dash dvd 2 10" subs 800watt amp.
    1999 Buick Park avesdf
    1971 Buick Electra 225 built 455 and turbo 400
    Sr. Apprentice TexasT is a glorious beacon of light
    Nov 2007
    Texas
    Synthetic will cost more, should withstand higher temp and last longer. Your call$$$ wise.
    I like to use the cheapest 'name' brand stuff. If it is red(Pink) and meets the standards on the bottle, I think it will work for me.
    More importantly to me is proper level and a trans cooler to keep it cool.
    Rich
    If I didn't have a Suburban I couldn't pull the toy box and haul my family to use the toys.
  5. #5
    Legend tlperry68 is a glorious beacon of light
    Oct 2008
    Huntington Beach, CA
    Trevor - Huntington Beach, CA
    2007 GMC 2500 4X4
  6. #6
    Sr. Mechanic Never Enough is a glorious beacon of light
    Oct 2008
    Grant, MI
    I'm an Amsoil or Royal Purple fan myself. Had good luck in the past with it.
    08 Z71 Victory Red Crew Cab
    Ground Force 2" drop in rear, 22" wheels, Toyo ST Rubber, K&N Intake, Magnaflow Duals, Bully Dog Prog., Weathertech Floormats, Grillcraft Grill, Undercover Sing Case, Viair Compressor, Wolo Horns, Hellwig F&R Sway Bars, Plasmaglow LED's, PEAK backup camera, Husky Mudflaps....lots more in the works.
  7. #7
    Jul 2008
    the nasti nati
    I like the redline trans fluid myself
