Results 1 to 8 of 8
    Sr. Apprentice thekingsphance is a glorious beacon of light
    Sep 2008
    Fairfield, CA
    Default leveling kit?
    Ok guys, I asked about getting a 2 inch lift on my truck on another thread and someone suggested I get a 2 inch leveling kit. I'm pretty inexperienced when it comes to lifts and I don't know what a leveling kit is or what it it would do for me. I googled leveling kits and it gives me front leveling kits. so you only raise the front end? or are there rear leveling kits too? If you do only raise the front end, how would the truck look with the back end a little lower than the front? Thanks for any time you spend helpin me out.
    2001 Silverado Z71, 5.3L, K&N cold air intake, flexalite electric cooling fan, Edelbrock shorty headers, Amsoil synthetic oil, dual exhaust flow master 40 series muffler, Hypertech max energy programmer, MSD Ignition plug wires.
    Legend retired2001 is a glorious beacon of light
    Nov 2006
    Canyon Lake, Texas
    Tlhe reason that you only find "front" leveling kits is that most pickups sit considerably lower in the front or higher in the rear, depending on how you look at it. This is so that if there is a load in the bed it will come closer to leveling out the truck as opposed to having the front setting high. Some kits I've seen offer 2 to 2.5" lift for the front and a "block" or add a leaf for the rear to make sure it is level and not higher on one end than the other. I hope this makes sense. Good luck!
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
    Sr. Mechanic Never Enough is a glorious beacon of light
    Oct 2008
    Grant, MI
    Yeah, if you want to go up, add a leveling kit in the front. If you want to go down, put a leveling kit (drop kit) on the rear. This is why a lot of drop kits are 2/4 or 4/6 drops because of the difference in height front to rear on your truck stock.
    08 Z71 Victory Red Crew Cab
    Ground Force 2" drop in rear, 22" wheels, Toyo ST Rubber, K&N Intake, Magnaflow Duals, Bully Dog Prog., Weathertech Floormats, Grillcraft Grill, Undercover Sing Case, Viair Compressor, Wolo Horns, Hellwig F&R Sway Bars, Plasmaglow LED's, PEAK backup camera, Husky Mudflaps....lots more in the works.
    Sep 2008
    Fairfield, CA
    Thanks alot guys that helps out alot.
  5. #5
    Jr. Apprentice cohen is a glorious beacon of light
    Sep 2008
    Chesapeake, VA
    crank the torsion bars! its free
    Cohen
    03 Silverado Z71 - Rough Country 2-1/2" Leveling kit, Bilstein 5100 series shocks, 33x12.50 Nitto Mud Grapplers , '06 17" Silverado rims, K&N 57 series CAI, Color matched bow tie, KC 57 series Hi-Lights mounted in grille, Pioneer 7" Double Din with iPod hookup, Cobra CB, Wilson 1000 antenna, billet grille, T-bar crank, removed side moldings, Bose
  6. #6
    Sep 2008
    Fairfield, CA
    would cranking the torsion bars be just as good as just installing the leverling kit?
  7. #7
    Legend 95CTburb19 is a glorious beacon of light
    Apr 2007
    Umass / Newtown CT
    not quite. You probably won't get as much of a gain as you would from a leveling kit (although you do get a decent amount) and your ride quality will suffer some. Also you will need to get an alignment if you crank the torsion bars.
    Dan
    1999 GMC Sierra 2500 350 vortec
    1967 Jeep M725 ambulance 230 tornado
    1990 Cherokee Limited- 3 inch lift on 33's
    ...and every one of em has issues
    If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
  8. #8
    Sr. Apprentice Kdogg05 is a glorious beacon of light
    Jun 2008
    Canada
    How hard is a leveling kit on your balljoints and front end compared to if you just left it stock?
Similar Threads
  1. Leveling kit
    By groceryman in forum Lifted & Offroad Suspension
    Last Post: 07-06-2009, 09:28 PM
  2. Leveling Kit
    By iPublicEnemy47 in forum Lifted & Offroad Suspension
    Last Post: 06-15-2009, 12:42 PM
  3. Leveling kit
    By Burden33 in forum Lifted & Offroad Suspension
    Last Post: 04-21-2009, 12:28 AM
  4. which leveling kit?
    By adampaul1964 in forum Lifted & Offroad Suspension
    Last Post: 02-13-2009, 05:48 PM
  5. Leveling Kit
    By gocubs68 in forum Lifted & Offroad Suspension
    Last Post: 01-31-2009, 07:01 PM
