Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Newbie tabascotk is a glorious beacon of light
    Aug 2008
    Default 95 burb with an engine issue
    I have a 1995 Suburban that I bought from a guy a little while ago. He had the engine rebuilt before I bought it and didn't drive it much. Anyway, the truck starts fine and runs fine until it's warm. Once it's warm, I get a strong gas smell, and when I come to a stop the engine sounds like it's going to die but doesn't. I had to replace the distributor on it because it was wore down. Also, when I'm cruising around 55, the engine shudders a bit. Anyone have any ideas on what could be causing this?
    Legend ct9a is a glorious beacon of light
    Jun 2008
    Colorado
    Maybe stuck open injector(s)?
    Scott
    ΜΟΛΩΝ ΛΑΒΕ
    '94 Chevy Suburban K1500
    3" exhaust w/ aero turbine non-baffled muffler
    CFM Technologies TB spacer
    CB w/ 44" whip antenna
    Aug 2008
    Oh, one other thing. I was driving over the weekend, and the service engine light came on for about 10 minutes. Then it just turned off. Could bad O2 sensor cause this?
    Sr. Engineer retired is a glorious beacon of light
    Nov 2008
    Glenside, Pa
    It could be anything take it your local mechanic and have him take a look at it for you.
  5. #5
    Jr. Apprentice opusd2 is a glorious beacon of light
    Dec 2008
    Are there problems with the engine when it is under load? If when warm you encounter these issues, it could be the ignition control module. Check your timing when warm, see if it advances.
  6. #6
    Dec 2008
    Or it could possibly be EGR related, it sounds like how a vacuum issue would act. Just two ideas that are easy enough to check out.
  7. #7
    Master Mechanic JMoney02 is a name known to all
    Oct 2008
    Brandon, FLA
    Quote Originally Posted by retired View Post
    Retired is right, at this point you have inherited another mans troubles, one who appears to not have enough mechanics backround. Unless you are willing to throw money at it then you should take the good advice and get it sound first then start to make it yours.......
    Jeff
    JMoney02
  8. #8
    Newbie abnsigo is a glorious beacon of light
    Nov 2008
    Did it run like this before the distributor change? If not, maybe the distributor is installed a tooth off. I did that when I changed a distributor and it ran similar to what you describe. Just a thought. Good luck.
    ABNSIGO (Stands for Airborne Sigo)
    '05 Z71 Suburban pulllin' a '73 Jeep CJ5
  9. #9
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    carbon canister will give you the gas smell when there is a problem with it
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  10. #10
    Sr. Mechanic Big6ft6 is a glorious beacon of light
    Jul 2007
    I think old gas sounds like most likely culprit.
    Otherwise, how does your truck start after it is warm? Does it take extra cranking? If so...
    Check your Coolant Temperature Sensor, it is easy to check resistance with a ohmeter (or just replace $11.99 autozone) becuase it is right in the front of the manifold next to thermo housing. The coolant temp sensor determines the air fuel ratio, if it is not working quite right...you'll be too rich once the engine warms up. AT least one possibility.
    Try to catch the check engine light when it is on next.
Similar Threads
  1. 97 Burb fuel delivery issue???
    By evilram in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 07-20-2010, 11:40 PM
  2. engine light issue
    By greenbastard in forum General Chevy Tech Q&A
    Last Post: 03-19-2010, 08:19 PM
  3. New 09 Silverado engine issue?
    By temmert in forum Powertrain
    Last Post: 02-19-2010, 02:26 AM
  4. UNBELIEVABLE- Need an engine due to crank issue.
    By 03TrailBlazer in forum Powertrain
    Last Post: 02-12-2009, 12:17 PM
  5. Pleas help with engine oil issue!
    By thekingsphance in forum Powertrain
    Last Post: 12-06-2008, 01:42 AM
