Results 1 to 6 of 6
    Sr. Apprentice javojjaaf is a glorious beacon of light
    Aug 2008
    bossier city/shreveport louisiana
    Default how much fluid?
    how much fluid normaly goes back in a 4L60 in a 98 z71 after a pan drop and filter change? thanks
    98 Z71 x-pipe and Magnaflow XL 3 mufflers
    08 Lancer GTS
    06 Honda 919 Hornet
    Sr. Engineer retired is a glorious beacon of light
    Nov 2008
    Glenside, Pa
    Dump 4qts in to start, then check. It could need as much as 2 more qts.
    Broke & Starving Student pmf608 has a reputation beyond repute
    Nov 2008
    Alberta, Canada
    12 Post(s)
    What retired said should be right - the extra is based on your dipstick as long as it is reliable. The dipstick in my 4L60-E is too long or something.. idk. when i had it at the right dipstick level, there wasnt enough fluid for the truck to even move. Mine is currently around 3 Quarts over 'full'. Hope you have better luck!
    Legend Crawdaddy has a reputation beyond repute
    Feb 2007
    1 Post(s)
    According to the Haynes manual, you should need at least 4 quarts. I'd say 4-6 should do ya. I wanna say that if you drain the torque converter you need more like 10 quarts to do the job, but that's ONLY if you drain the torque converter.
    Christopher
    1991 Chevy Suburban 1/2 ton 2WD w/ chevy SBC 350-3/4 ton drivetrain upgrade w/4.10 gears 194K miles
    2005 Saturn ION-2 Stock 200K miles (In 6 years...ouch)
    1982 Bronco, 1993 Bronco, 1971 M35A2 Deuce and a Half
  5. #5
    Master Mechanic JMoney02 is a name known to all
    Oct 2008
    Brandon, FLA
    Quote Originally Posted by retired View Post
    As Retired stated, add 4 qts, warm up and shift to different gears holding brake, until operating Temp, check stick and add as needed, which should be almost another 2 qts. Then test short trip and see what reads on the Stick.......
    Jeff
    JMoney02
  6. #6
    Aug 2008
    thanks for all the help guys. i checked it this morning after putting one gal. in after the change and it looks good when cold, but ill take a look at it when i get to work.
    08 Lancer GTS
    06 Honda 919 Hornet
Similar Threads
  1. Should I add some fluid to my differential?
    By ibmoses in forum Powertrain
    Last Post: 08-30-2009, 05:19 AM
  2. What transmission fluid should i use?
    By nos351wcm in forum Powertrain
    Last Post: 08-28-2009, 10:57 AM
  3. how much transimission fluid?
    By chasin7 in forum Diesel & DuraMax
    Last Post: 08-28-2009, 07:46 AM
  4. Tranny Fluid
    By NRC34 in forum Powertrain
    Last Post: 12-31-2008, 08:25 PM
  5. Fluid Leak
    By dwill3015 in forum Automotive News
    Last Post: 12-21-2007, 05:14 PM
