Results 1 to 2 of 2
    Newbie bartle00 is a glorious beacon of light
    Jan 2008
    Default Rough running when cold out
    When it's cold old side and it's been sitting over night and I start it up; it will start, but all my lights are dimming and my battery gauge fluctuates. I have a CD player that shows my voltage for the battery and it can drop down as low as 10.3 volts and then goes back up and down until the truck warms up and then it is better, but not perfect. It is fine in temps at about 25 degrees and up, but when it get colder it gets really rough. Then while that is happening and I try to drive my headlights and tail lights dim down almost like they are not on.
    -my dad is a mechanic and he says it's not the battery or an alternator. He thinks it is something behind the instrument panel. We think it is a short somewhere. Can you help us out with this?
    Any help with this would be greatly appreciated!
    Master Mechanic TahoeFever has much to be proud of
    Sep 2007
    Now IN Auburn AL :)
    sounds like a bad ground somewhere usually after a few years the grounds start to corrode and get week...
    if you got headlights dimming and stuff then you really got a bad ground or a bad connection start with the cables in the block then work your way up
    usally with a bad short the truck will just quit out on yah all together .
    04 Tahoe LT 5.3L stock MSD 8.5mm Wires
    Gigbson Duels Straight Exhaust, Parrot 3100 Bluetooth
    K&N 77 Series CAI, Sirius Radio
    De-badged, Valet Dei remote start
    5000k HID -Higherlevelauto.com
    Federal 100watt air horn
Similar Threads
  1. Running Rough!
    By cwarrenburgess in forum Powertrain
    Last Post: 05-03-2010, 02:18 AM
  2. 1996 5.7 running rough
    By 1996k1500 in forum General Chevy Tech Q&A
    Last Post: 04-06-2010, 09:44 PM
  3. Rough running condition at cold start
    By japsmash2001 in forum General Chevy Tech Q&A
    Last Post: 01-08-2010, 05:59 AM
  4. rough running
    By heaviechevie in forum General Chevy Tech Q&A
    Last Post: 10-16-2008, 06:05 PM
  5. 94 Suburban running rough..HELP
    By AllenH60 in forum Powertrain
    Last Post: 08-04-2008, 02:50 PM
