Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Newbie philg_05 is a glorious beacon of light
    Nov 2008
    Atchison, KS
    Default Level truck?
    Kinda new here. Bought a '03 1500 hd about a month ago and was wondering what the the best way to level the truck? I've noticed that the front sits quite lower than the back. Also, any suggestions for improved gas mileage would be great. Already have aftermarket Magnaflow split rear exhaust and tonneau cover. Was considering a chip, but no idea about what to get. Any and all replies much appreciated.
    Thanks,
    phil
    Legend 04sierracrewcab is a glorious beacon of light
    Aug 2008
    Deer Park Texas
    welcome!
    Glad to have you!
    I would recomed Daystar coil spring spacers.
    I got mine for 140.00 they instaled in about an hour.
    You can get a KN air intake (stage 2) to get your HD breating better.
    I Will be getting the Superchips Flashpaq which will give you better milage (if you can keep your foot out of it)
    Ryan
    2002 Jeep Wrangler Sport 4x4 (the Yellow Jacket)
    4inch suspension 3inch body
    Straight 6 (383 Stroker within a year)
    36inch SuperSwamper TSL.
    105,000
    Detroit Loccers
    Daily Driver Weekend Wheeler
    much more...
    2004 Sierra crew cab, 2wd, 5.3 V8
    2inch Daystar Leveling kit
    single dumped Flowmaster 40 sieries exaust(removed)
    Mb Blitz Chrome wheels
    Leer Bed Cover(for sale)
    50k miles
    Moderator
    dwill3015 has a reputation beyond repute
    Jan 2007
    Yacolt, Washington
    Welcome to the site!
    In case your HD is a 4X4, look at torsion bar keys for leveling the front.
    Darcy
    Washington State
    Legend 95CTburb19 is a glorious beacon of light
    Apr 2007
    Umass / Newtown CT
    Welcome to the forum! There are tons of posts on here about cranking the torsion bars and leveling kits. Here is a link to more info on torsion bars that was posted by another member. http://www.avowners.com/forum.idc?sh...s&TID=870&PN=1
    Hope this helps!
    Dan
    1999 GMC Sierra 2500 350 vortec
    1967 Jeep M725 ambulance 230 tornado
    1990 Cherokee Limited- 3 inch lift on 33's
    ...and every one of em has issues
    If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
  5. #5
    Legend
    Pete95Sierra is a name known to all
    Jan 2008
    Morristown, NJ
    rancho quicklift is a good but more expensive option. you can also crank the torsion bars as darcy said. as for programmer the people here seem to to like the hypertech's
    PETE
    95 GMC Sierra 2500
    3" Body Lift, 33" Goodyear MTR's
    5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
    Sold :(
    1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
    2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
    Contact this GMTC Moderator for any problems or questions you may have
    Join the GMTC Facebook Group!!! Join Here
  6. #6
    Sr. Apprentice thekingsphance is a glorious beacon of light
    Sep 2008
    Fairfield, CA
    I have the hypertech max energy programmer myself. It's a pretty nice piece of equipment to have. It reprograms your computer with software that is dyno tuned for your vehicle for more efficient engine operation over all. You can modify your engine and drivetrain paramaters like increasing or decreasing your transmission shift firmness, rev limiter, you can also tell the computer if you're running larger tires so it can calibrate your speedo to read correctly. I noticed some HP increase but not sure about MPG gains. get the Hypertech if you can drop about 350 bucks.
    2001 Silverado Z71, 5.3L, K&N cold air intake, flexalite electric cooling fan, Edelbrock shorty headers, Amsoil synthetic oil, dual exhaust flow master 40 series muffler, Hypertech max energy programmer, MSD Ignition plug wires.
  7. #7
    Sr. Apprentice SlickMachine is a glorious beacon of light
    Nov 2008
    Stow, OH
    Welcome.
    For what its worth, I run the Hypertech performance program on my '05 5.3L and I noticed very minimal power gains. The only place I noticed anything was at wide open throttle as the engine accelerates through 4000 RPM's where it does "pull" a little harder. The benefits of this programmer are found in the ability to adjust for tire size, gearing, and shift firmness. Also nice is the removal of top speed and rev limiters as the 323 engine likes to rev. So don't expect tire-melting power from the programmer. If straight horsepower and mpg is what you want, then I would spend the money on headers to compliment your exhaust. I think the difference will be more noticeable there. Or, as someone else mentioned, an intake (which would be a cheaper route).
    2005 Sierra 1500 Z71 Crew Cab
    Pro Comp 6" Lift
    4.56 Gears
    35" Toyo M/T's on 20" Eagle Alloys
    K&N Intake
    Flowmaster Exhaust
    SuperChips Programmer (worthless)
  8. #8
    Newbie Lifted33 is a glorious beacon of light
    Nov 2008
    You can also buy key's to get more out of the torsion bars.
  9. #9
    Jr. Engineer bassalive is a glorious beacon of light
    Nov 2008
    Marne, New Brunswick Canada
    Daystar coil spring spacers man.Easy and Economical!!!!!!!!!
    Troy
    New Brunswick, Canada
  10. #10
    Legend
    Jan 2008
    Morristown, NJ
    is your truck 2wd or 4wd? with 2wd trucks they have coil springs and you can use a spacer, with 4wd you can crank the torsion bars.
    Also, fill out your sig so we know a little more about your truck
    PETE
    95 GMC Sierra 2500
    Sold :(
Similar Threads
  1. how to level the front of the truck?
    By elkosp16 in forum General Chevy Tech Q&A
    Last Post: 07-05-2010, 11:12 PM
  2. ReadyLift - front level kit or SST lift/level kit
    By JW2007-6.0 in forum Lifted & Offroad Suspension
    Last Post: 03-13-2010, 03:07 AM
  3. Level Truck to bring Front End Up?
    By BandungBaby in forum Lifted & Offroad Suspension
    Last Post: 02-28-2010, 03:14 AM
  4. Truck Not Level Springs Sagging?
    By 89formularoth in forum Lifted & Offroad Suspension
    Last Post: 03-13-2009, 08:45 PM
  5. Gonna level my truck
    By ewarz in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-01-2008, 11:17 PM
