I just got a 2000 silverado 2wd lowered with 255/35/20 but the speedo is off VERY BAD!!!
Like 7 mph what tire size would correct this?? Thanks
this is a redisgned 2000 not the old brick style truck, i could be wrong but it might have to be adjusted by the computer, so get a programmer, fix the sdeedo and get a little better performance at the same time
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
but can i do this by changing tire size?? im in need of new tires
I'm no tire expert, but I think that if you plan on keeping the 20's, you're going to be going with a really small sidewall. Do they make sidewalls smaller than 35's? If they do, I would imagine it would be pretty expensive. Might be cheaper to adjust the computer/speedo its self as suggested above.
you need a bigger side wall then 35 you only have 20's if you went and got a new chevy with optional 20 it would be around a 45 or 50 side wall, so if it says 55 you are at 48 actually you have a smaller diameter then you should so at the sensor either at the wheel or in the driveline somewhere it says so many revolutions at this interval is this speed but the computer doesnt know you have a smaller overall diameter tire. go to tirerack.com and put in your truck and look for tires for 20 inch rims, you need thicker sidewall dude! my $.02. if the correct size tires are too big for the truck and they would rub cuz its lowered then you have to get a programmer to account for it
Hypertech III
Reg Cab Long Box
Jason
I am have a 2002 2wd 5 speed.that i just changed tire size on the computer..with a tech 2 go under chassis and special functions and you can change your tire size..not sure that it goes all the way up to 20 inch wheels it offers about 50 options of sizes.
tirerack.com says 285/50/20 just to let you all know thanks for the help
josh
Dan
1999 GMC Sierra 2500 350 vortec
1967 Jeep M725 ambulance 230 tornado
1990 Cherokee Limited- 3 inch lift on 33's
...and every one of em has issues
If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
you can get speed calibrators, or you can get a programmer that will correct it for you if you put in the tire size
PETE
95 GMC Sierra 2500
3" Body Lift, 33" Goodyear MTR's
5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
Sold :(
1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
Contact this GMTC Moderator for any problems or questions you may have
Join the GMTC Facebook Group!!! Join Here
X2 on the programmer i had to the same with my 20's even though i went from a 17
04 Tahoe LT 5.3L stock MSD 8.5mm Wires
Gigbson Duels Straight Exhaust, Parrot 3100 Bluetooth
K&N 77 Series CAI, Sirius Radio
De-badged, Valet Dei remote start
5000k HID -Higherlevelauto.com
Federal 100watt air horn
Bookmarks
