my 97 tahoe has a prob of warping rotors prematurely. i believe it is due to undersized rotors. i dont have the cash to do a big brake swap, however i am wondering if swapping out the stock standard rotors for stock sized slotted and drilled rotors? if that would help with heat dispertion? being the heat that is causing the warping from not being able to disperse the heat properly
I can't say for sure, but it makes sense to me. That is the main reason for the grooves and cross drilling. Good luck!
2010 Z/71 Colorado C/C
Black 4X4 w/5.3L V8
2007 Winnebago Adventurer
w/8.1L Chevy & Allison 6spd.
Canyon Lake, Texas
Drilling allows the rotors to cool and also helps remove dust. The slots will remove alot more dust and they actually resurface the brake pads. Like a wood plane does to wood. this gives you clean new braking surface all the time. However the brake pads wear out sooner.
BRYAN
"IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
02' Avalanche 2500 Onyx Black
8.1L Vortec
43,000 miles
Let us know what happens.
Trevor - Huntington Beach, CA
2007 GMC 2500 4X4
tanx all will keep yall posted on how it goes
Sounds like you have a heavy foot?
the slots and drill holes allow the gasses emited durring brakeing between the pads and rotors to escape it provides better cooling for the rotors as well..the result is much better braking and longer brake life.they are a very good investment and do help alot
99 silverado 4.8l with 6.0 throttle body,full tci rebuild with shift kit transmission with no reverse,eaton posi,flowmaster exhaust
97 s10 350 pushing 350hp,5 speed trans,headman headers...kenwood in dash double din touch screen dvd,kenwood 6 disk changer-just a project truck
Ricer: from the latin word Ricarius meaning to suck at everything you attempt
A person who makes unnecessary modifications to their most often import car (hence the term "rice") to make it (mostly make it look) faster. The most common modifications are (but not limited to):
- Huge exhaust that serves no purpose but to make the car louder
- Large spoiler on the back that looks like something Boeing made for the 747
- Lots of after-market company stickers they don't have parts from, but must be cool
- Expensive rims that usually cost more than the car itself
- Body kit to make the car appear lower, usually accented with chicken wire
- Clear tail lights and corner signals
- A "performance intake"- a tube that feeds cold air to their engine usually located in areas of excessive heat (behind or on top of the engine)
- Most of these riced cars (a.k.a. rice rockets or rice burners) are imports; Honda Civics, Accords, Integras, CRXs, RSXs, Del Sols Mitsubishi Eclipses, Lancers, Subaru Imprezas, however there are some domestics such as Chevrolet Caviliers, Dodge Neons, Ford Focus; small, slow, economy cars designed specifically to go slow. Please note that some 3000gt's Supras, Skylines, WRX's and other higher performance imports are designed to go fast, and are therefore not always considered rice, but it really depends on the severity of the case.
(courtesy urban dictionary)
04 Tahoe LT 5.3L stock MSD 8.5mm Wires
Gigbson Duels Straight Exhaust, Parrot 3100 Bluetooth
K&N 77 Series CAI, Sirius Radio
De-badged, Valet Dei remote start
5000k HID -Higherlevelauto.com
Federal 100watt air horn
when youre stopping there are gasses emitted from the friction on the pads and rotors it in turn makes a very small pocket of gas between the pads and rotors.. and no it wouldnt be from a fluid leak guess you need to look at a few tech videos to know about it
There are many claims as to the benefits of drilled vs slotted rotors on stopping power. This guide is intended to provide some facts about drilled and slotted rotors. As a member of the SAE (Society of Automotive Engineers), I was pleased to see a paper "The Effect of Rotor Crossdrilling on Brake Performance" by two GM engineers published in 2006. They examined three vehicle platforms with cross-drilled rotors vs standard rotors to measure convection cooling capability, fade characteristics, wet braking, pedal feel and lining wear. The result is summarized as follows:The authors also reported that drilled rotors prevent pad resin glazing on the rotor. So we now have solid evidence that drilled rotors have benefits over standard rotors. However, I have not found any published paper to show how slots affect brake output. So I reviewed inertial dynamometer tests using ISO NWI 26867 from Link Testing in Detroit with slotted rotors vs standard rotors. The results showed no significant difference in the coefficient of friction during the fade sections, hot stop section or pedal sensitivity portion of the test. My hypothesis is that slotted rotors do not contribute to rotor cooling whereas drilled rotors improve convection heat transfer to cool rotors and reduce brake fade. I should also point out that the pad lining wear for the slotted rotor was very severe during the test, i.e. the pad was chewed up over 20% more than the lining with stock rotors. While I believe that slots will help remove gas and debri from under the pad, I am not sure that this has a significant effect on brake torque for normal street driving. Perhaps the effect of slotted rotors is more significant on the race track, and conversely, I believe that drilled rotors are better for street and highway driving. For most drivers, I recommend drilled rotors over slotted rotors, and this conclusion is supported by the fact that Corvette, Ford GT, Porsche, Mercedes and BMW come with OEM drilled rotors
- For the sports sedan, the coefficient of friction was 21% higher for drilled rotors than standard front rotors at 340F and higher using 15 brake snubs at 62mph. The track simulated 124 mph fade test showed 37% better brake output for drilled rotors. The drilled rotor brake temperature was about 150 degrees cooler.
- For the performance car, the coefficient of friction was significantly higher for drilled rotors especially at high temperature.
- Wet braking at high pedal pressure was the same for drilled or standard rotors. Wet braking is not significantly improved by drilled rotors.
- Pedal force was much more consistent with drilled rotors over the brake temperature range. That is, to stop at the same deceleration rate, the driver does not need to modulate pedal pressure based on different brake temperatures. This reduces driver fatigue and improves brake response.
Bookmarks
