Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Jr. Mechanic mudpuppy is a glorious beacon of light
    Jul 2007
    il
    Default surging 1994 Chevy Suburban
    first of all yaayyaayaa im back. now here it is i got a 94 burban and when not in gear the idle jumps about 200-500 rpm. only while not in gear. or atleast i cant notice it when in gear. no its not a vacume leak. me and 5 others have checked it for that. every sensor is new. new fuel pump and psi checks 5.0. timing checks 5.0. new computer. no codes popping. just about the only thing left is the injectors, what do you guys think?
    94 sub 6inch lift 34inch bfg mt. 3 audioque 2.0 12's duel 4ohm vc at a 1.3ohm load and 1 jl 13w7 duel 1.5ohm vc at a 3ohm load until the hdc3 12 gets here, 2 jl 6.5 components, 2 boston acoustic 5 1/4 components, 4 bose 6.5 extreme duty mid drivers, 4 super tweeters. 4 planet audio amps 1250.1 300.2 150.2 150.2, 1 jbl 1200.1, 1 kicker 100.4. 4. 4 new kc daylighters,4.88 fwd and aft gears with Richmond locker, 600hp built 4l60e with 2400rpm stall, stock engine.
    Sr. Apprentice Steban is a glorious beacon of light
    Nov 2008
    san diego, ca
    my first guess was a timming issue but you said you already checked that. what about your TPS sensor?
    Legend ct9a is a glorious beacon of light
    Jun 2008
    Colorado
    Could be the injectors if its a TBI 350. Supposedly they aren't matched very well at all from the factory.
    Scott
    ΜΟΛΩΝ ΛΑΒΕ
    '94 Chevy Suburban K1500
    3" exhaust w/ aero turbine non-baffled muffler
    CFM Technologies TB spacer
    CB w/ 44" whip antenna
    Master Mechanic daddytech is a glorious beacon of light
    Mar 2008
    Portland TN
    Have you had someone check out the transmission ???? might look at that if you have checked everything else out and its all ok. I would have also thought about the TPS or Map sensor, sometimes those will show no codes and still not function properly , just a thought.
  5. #5
    Nov 2008
    san diego, ca
    Quote Originally Posted by daddytech View Post
    sometimes there is a fluke in the sensor. the best way to check it is you use and analog meter and chek the ohms values while you move the sensor. if something is wrong you see the needle jump or dive.
  6. #6
    Jun 2008
    Colorado
    Also, I don't know if the GM trucks have this problem or not, but on some of the motors that I'm used to working on an air pocket in the coolant system will cause this as well.
    Scott
    ΜΟΛΩΝ ΛΑΒΕ
  7. #7
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    I cant remember but does that have a MAF sensor or IAC, my old cavalier had an IAC and when that would get gummy it would idle rough easy clean with carb cleaner though
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  8. #8
    Jul 2007
    il
    maf and tps senors have been replaced tring to fix this prob and no resolve
  9. #9
    Jul 2007
    il
    the tranny is a 4L60e, if 1 of the elect valves are bad wouldnt that pop a code or is there a differant way of checking that? i will say(it hasnt done this for some time now) it has had problems downshift when coming to a full stop. i was told it might be 1 of the elect valves in the tranny, not sure how they would or even might effect the idle though.
  10. #10
    Legend 04sierracrewcab is a glorious beacon of light
    Aug 2008
    Deer Park Texas
    Quote Originally Posted by ct9a View Post
    Agrreeed, I have heard that too
    Ryan
    2002 Jeep Wrangler Sport 4x4 (the Yellow Jacket)
    4inch suspension 3inch body
    Straight 6 (383 Stroker within a year)
    36inch SuperSwamper TSL.
    105,000
    Detroit Loccers
    Daily Driver Weekend Wheeler
    much more...
    2004 Sierra crew cab, 2wd, 5.3 V8
    2inch Daystar Leveling kit
    single dumped Flowmaster 40 sieries exaust(removed)
    Mb Blitz Chrome wheels
    Leer Bed Cover(for sale)
    50k miles
Similar Threads
  1. 1990 Chevy-305 Surging Engine
    By Air Force One in forum General Chevy Tech Q&A
    Last Post: 11-04-2009, 01:12 PM
  2. URGENT: 2002 Suburban Z71 Idling Rough and Surging
    By perfect777 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-14-2009, 10:33 PM
  3. 1994 Chevy Suburban - Seats and/or Carpet
    By iukini in forum General Chevy Tech Q&A
    Last Post: 01-12-2009, 01:19 PM
  4. 1994 Chevy Suburban Won't Start
    By Nazimek442 in forum General Chevy Tech Q&A
    Last Post: 06-14-2008, 09:00 AM
  5. Selling 1994 Chevy Suburban 1500 Silverado
    By theburmanbunch in forum For Sale & Wanted to Buy
    Last Post: 04-07-2007, 12:29 PM
