Hey guys my steering wheel is getting stuck when I want to turn left. When I turn the wheel to the right its fine it never gets stuck but when I turn it to the left, it’s really hard to turn. Sometimes it turns fine but the majority of time it’s really hard. I checked the power steering fluid and its fine it’s not low. Does anybody know what can this problem be? How hard is it to fixed knowing the problem and how much am I looking at for the part. Thanks a lot guys
check to see if you steering linkage is binding
1998 GMC Sierra SLE- Bone stock engine, 4'' in dash dvd 2 10" subs 800watt amp.
1999 Buick Park avesdf
1971 Buick Electra 225 built 455 and turbo 400
steering linkage binding? am not sure where that is located and how does it look like.
the shaft coming out of the firewall located inline with the steering wheel
if it is binding, how would i be able to tell. If it looks fine any ideas in what else it can be.
Jack the truck up in the air and get under it while someone turns the wheel (please use jack stands!) and see if the linkages are hitting anything. If not, then I would start looking at the steering rack and maybe the end links.
Type of truck(Make,Model,Year), has the failure be sudden or gradual? Any noise associated with the problem? Truck being maintained, origianl owner, purchased used? Have the necessary tools to perform diagnostics on the truck? Daily Driver, or have another vehicle while this is layed up? All above are a start, along with power steering jamming to one side, pitman arm, lack of grease and hard bind.....
Jeff
JMoney02
If your not sure on what your looking at let a mechanic look at it.
My '99 Z71 did that and it was the stearing gear box, Bought one from the salvage yard for $75 and paid my mechanic $50 to put it on.
Check your tire pressure. May be as simple as an under inflated tire. It sounds like the problem I had last winter
Pete
"ROCK YOUR RIDE"
Bookmarks
