i have a 350 TBI was parked for about a year but started every week or so.... It ran fine yesterday then last night it acted like it ran out of gas ..... was it does is when you take off from a stop it falls flat on its face .... won't accelerate .... but once you get pass that it runs fine until you come to a stop again... thought it was clogged cat pulled that off ... fuel filter changed.. plugs and wires .... can't figure it out ..... y'all help would be greatly appreciated ....
thanks
Greg
could be a throttle position sensor or a bad injector
1998 GMC Sierra SLE- Bone stock engine, 4'' in dash dvd 2 10" subs 800watt amp.
1999 Buick Park avesdf
1971 Buick Electra 225 built 455 and turbo 400
What year 350 TBI? Is your check engine light on?
Darcy
Washington State
Bad gas, fill the tank and take it out and run it for awhile.
yeah fill it up and threw some seafoam in it we'll see what it does....... it's an 89 and no light
but i will check to see if it has any codes in the morning thanks guys
greg
Check MAP sensor, appears to stumble from lack of Air Mixture. When you state "You get Past That", so when you get a certian RPM range it starts to run correctly? What about when you kick it down when
it runs correctly, does it stumble and then go again? If yes to all this, MAP... Also, you fuel will varnish after
sitting for so long without stablizer, cause the throttle body to have problems also. Drain the fuel and start fresh.
Jeff
Last edited by JMoney02; 12-07-2008 at 05:14 AM. Reason: more info, MAF to MAP correction by ct9a
JMoney02
any updates? i have a similar problem and cant figure it out.
Bookmarks
