GM Truck Club
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Leaky injector could cause this, but I would also think that there would be other symptoms too. Might be worth looking into though.
    I assume there's no CEL?
    Scott
    ΜΟΛΩΝ ΛΑΒΕ
    '94 Chevy Suburban K1500
    3" exhaust w/ aero turbine non-baffled muffler
    CFM Technologies TB spacer
    CB w/ 44" whip antenna
  2. #12
    Master Mechanic
    Oct 2008
    Brandon, FLA
    EGR/switch getting stuck on warm starts and functioning when in operating mode? Pindle stuck at start due to extreme carbon build up, but will not produce smoke when running. You have to hold the pedal
    down to get it to start when warm? How do your spark plugs look? Just check the easiest one and see how black it is and lets see what you get here...
    Jeff
    JMoney02
  3. #13
    One thing you might want to check is your coolant temperature sensor.
    the coolant temp sensor signal acts as a choke on fuel injected engines, when it is cold it puts more gas in the engine (like pulling the choke on your lawnmore when you first start it) and as your coolant temp warms up, it tells the computer to lean out the gas mixture.
    If the sensor is bad and is sending a cold coolant temp to computer, the computer would always be putting too much gas in. When you're starting from cold, that wouldn't be a problem, but when your engine is already warm, the air/fuel mixture would be too rich to start well and you'd need to open the throttle (pump the gas) to get more air in to allow it to start..the extra gas would come out as incomplete combustion and carbon deposits (black smoke)
    New sensor is only $11.99 and can be checked with a ohmeter
    Only thing is usually a bad CTS would cause a CEL code...but maybe it isn't bad enough to throw a code.
  4. #14
    Legend
    Feb 2008
    Red Wing, Minnesota, United States
    black smoke is usually the by-product of your engine running rich, I would be checking the intake and TBI
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
  5. #15
    My first thought is fuel pressure regulator. What happens is the diaphragm between the pressurized fuel and the vacuum line ruptures, allowing excess fuel into the intake. If the leak is slow enough, you don't see a problem while it's running, but, once you shut off the engine, the fuel system "depressurizes" through the FPR into the intake. Once you get enough in the intake, it will act "flooded" when you try to start it. If you wait long enough, the excess fuel in the intake will dissipate and you don't have a problem.
    Easy enough to check: simply pull the vacuum line off of the FPR (As I understand it, your 7.4 FPR is easy enough to get to) after the engine's been running and see if there's any gasoline in the vacuum line. If yes, then replace FPR.
    If no, I'd probably put a fuel pressure gauge on it and see if the fuel system holds pressure.
    '98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
    '92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
    "My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
Similar Threads
  1. black smoke
    By dshewy14 in forum General Chevy & GM Tech Questions
    Last Post: 08-02-2010, 09:38 AM
  2. HOW TO smoke your lights
    By mill8365 in forum Chevy Truck Accessories
    Last Post: 03-10-2010, 09:53 PM
  3. 03' 6.6 wont start when motor is warm
    By hondahauler in forum GM Diesel & DuraMax
    Last Post: 08-20-2009, 10:05 AM
  4. Replies: 7
    Last Post: 01-16-2009, 01:04 PM
  5. I got smoke where there shouldn't be any
    By chicksuv93 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-28-2007, 09:56 AM
