GM Truck Club
Page 3 of 7 FirstFirst 12345 ... Last Post byLast Post by
Results 21 to 30 of 68
  1. #21
    Jr. Mechanic GOTSAND4ME2's Avatar
    Apr 2009
    Ukiah, California
    Just got done with my bulb swap and here's the scoop
    Get some new bases from bulbtown.com part number pc194 Better thank stock
    Get some led bulbs any color from superbrightleds.com part number wled-x4 I got the blue option (just a warning tho the wled-4 bulbs are REALLY bright) if you don't want them that bright get the wled-2
    Hope this helps someone who is considering doing this
    Brian
    Nor-Cal
    2000 Chevy Silverado 1500
    6" RCD Lift
    315/75/R16 BFG All Terrains
    Alpine 7" DVD Reciever
    Jbl Componet Door Speakers Front and Rear
    4 10" Jbl Subs
    Led (Blue) Cluster Gauge Blulb Swap
    Dell Studio Hybrid Digital Media Server
    Cobra CB
    Twin Bearcat Scanners
  2. #22
    Update: I just ordered a bunch of LED's off of ebay. When they get in, I will update this thread on how to convert the heater controls and all lighted switches to LED also.
    2008 FORD F350. My new all-around truck.
    2001 Silverado Reg. Cab Not-So-Base -- SOLD
    2003 Avalanche Z71. No Cladding. Check out my Mod thread. - Crashed. Will be rebuilt soon.
    1974 Triumph Spitfire 1500 - Work in Progress
    2003 Sierra 3500 Duramax. The Newer, Better Work Truck -- FOR SALE
  3. #23
    Sr. Apprentice
    Jan 2006
    bogalusa, la
    Default cool
    man that trick was a good touchj good job!
  4. #24
    Quote Originally Posted by pmf608 View Post
    Did you ever get those LEDs? I am anxious to see if you were able to modify the heater control lighting!
    2006 GMC Sierra 2500HD Duramax
  5. #25
    Quote Originally Posted by aboston View Post
    Great write-up!
  6. #26
    Master Mechanic TritonBoulder47's Avatar
    Nov 2009
    Tunkhannock, PA (North East)
    Quote Originally Posted by vncj96 View Post
    I like the blue! Is there anyway to change the color of the needle on the cluster though???
    You can buy a different needle kit... I've seen kits that are just the replacement needles...
    Tim a.k.a. Da' Boulder
    2003 Chevrolet Avalanche Z71 - Custom Emergency Response POV
    Firefighter, Fire Policeman, Ambulance Driver, Rescue Tech, Emergency Lighting Installer
    Tint, 20's, Bull Bar, Intake, Exhaust, Billet Grill, Stereo, Custom Console, Emergency Equipment, and the list goes on...
  7. #27
    Sr. Apprentice
    Nov 2009
    Great Falls MT
    Do you know how different this process would be on a 97? I really want to do this.
    Andy aka Shmeag
    97 Silverado Z71
    5.7 350
    2'' lift
    2 10'' subs 800w amp
  8. #28
    I totally forgot I had posted that. yes, the LED's came in. I used standard 5mm and 3mm LED's because to the best of my knowledge there is no premade LED designed for this specific application. I picked up a second heater control for a dollar at a swap meet, so i used that for my swap. All you have to do to change the heater controls is open it up (remove screws, pull the knobs off so you can access the front of the circuit board). Just pull the white plastic away from the unit. If you try to pry the little clips on the side, you are more likely to break them than accomplish anything. Once it is open, all you have to do is desolder all the existing bulbs, and solder in an LED with the proper resistor. You can also remove the little circuit board at the bottom and swap out the bulbs in there (for the air recurculation, defrost, A/C buttons, etc - these had been burnt out on both my units, so i though they didnt have lights at all). If you want more even lighting and are good with that stuff, you can find a way to put a couple more led's in, such as behind the red on the temperature knob, which is a bit more difficult to see. I used 5mm blue LED's for the main circuit board, with the proper resistors that came with them. For the smaller circuit board, I used 3mm blue LED's with the same provided resistors. I do not have pictures of the process, but if you are good with a soldering iron, it is pretty straight forward. I am on holiday in Phoenix now, so when I get back home to Canada, I will take some night pictures of the finished result.
  9. #29
    Awesome. I would love to see the finished result. Do they match the other bulb colors on the cluster?
    Can't wait for those pics! Have a good vacation
  10. #30
    this would be an awesome mod to go with my blue footwell lights. and hard would it be to paint the needle a different color?
Similar Threads
  1. 2002 Tahoe left front turn signal bulb?
    By colfrank in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 04-19-2010, 05:09 PM
  2. Known issues 1999-2002 Silverado
    By 4DGS in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-29-2009, 12:19 AM
  3. 1999-2002 Chevy Silverado and GMC Sierra Parts CD
    By ChevyFan in forum Chevy Parts eBay
    Last: 08-14-2009, 01:30 PM
  4. 1999-2002 Chevy Silverado and GMC Sierra Parts CD
    Last: 07-06-2009, 09:40 PM
  5. Gauge bulb replacement
    By pmf608 in forum Audio, Video & Gadget Tech
    Last: 12-16-2008, 04:47 PM
