New problem.... I've changed the front brakes without problem, but low and behold I go to do the rear set and as luck would have it the bolts have torx heads...minor set back, the real problem is that I can't get my air rachet with the torx head between the bolt head and the leaf spring. Any ideas on how I can do this without removing the springs?
KennyD
Come on guys....somebody has got to have an idea how I can approach this
KennyD
Sorry Kenny, I have an 06 2500HD but have not had to touch the brakes with only 31k on my truck. I did read this on one of my diesel sites I frequent. hope it helps....
Pins and caliper bracket bolts are a pain to get loose. Pins take a torx t-55. I had to use a pipe wrench and a t-55 in a socket to get the top ones loose. The bottom one needed a cheater on a 1/2 ratchet. The bolts holding the caliper bracket have some type of lock tight on them and are very hard to break loose. Once loose they take a wrench all the way out. The rotors were tight. I used a pry bar and a 16 oz ball pean. Pry, hit a few times, turn rotor 1/4 and repeat. I takes a few revolutions to get the rotor off. All of my pads looked fine. I still cant find the chatter mine makes when braking. Used a dial caliper on rotors, at most .005 out.
Darcy
Washington State
Use a regular ratchet?
I tried a regular rachet...still to tight to get a rachet in between the bolt head and the spring
KennyD
Do you have a torx that sticks out 3" or is the issue that you have limited room for the torx?
Trevor - Huntington Beach, CA
2007 GMC 2500 4X4
A swivel and extension with the T-55 socket after you have broken lose? First time remvoing these?
dwill3015 is right, after the initial breakage, then you can use the swivel and Ext.....The air as well.
Jeff
JMoney02
Bookmarks
