    Question Cold starting issue!
    i have a 97 Sub that is a pain to start when cold but runs super, any ideas well appreciated!
    Happy 2 Wheeler!
    Cold air temp sensor could be out of range.
    Quote Originally Posted by retired View Post
    Thanks for your reply! No all I need to do is figure out where it is located and change it out.
    Phil
    Happy 2 Wheeler!
    Cold air temp should set off the check engine light. Might also be the fuel pump relay. If it goes bad, the fuel pump wont come on until the oil pressure comes up, which result in a long "cranking" session. Can you hear the fuel pump run for a few seconds when you turn on the key?
    Gary
    99 K 1500 Suburban
    00 S-10 Blazer
    1976 Trans Am
    1980 Honda CB900 Custom
    I hear the pump kick in witht he key it seems to pressurize pretty quick under 10 seconds, also it runs great just is cranky when its is cold 3o degrees or less. In 45-50 it only turns about 1/2 to 3/4 of a turn and it is running, very quick start.
    Phil
    Happy 2 Wheeler!
    Cap, rotor, plugs and wires.
    Scott
    ΜΟΛΩΝ ΛΑΒΕ
    '94 Chevy Suburban K1500
    3" exhaust w/ aero turbine non-baffled muffler
    CFM Technologies TB spacer
    CB w/ 44" whip antenna
    Sr. Apprentice smainsw's Avatar
    Dec 2007
    Ontario, Canada
    You might also want to look at how many cold cranking amps your battery is rated at, also if your battery is getting old it might not be able to supply the necessary current to turn over your engine in the cold mornings, however 30 degrees really isn't all that cold to be having issues starting your truck from battery related issues, but hey you never know.
    2005 Chev Silverado Z71
    Magnaflow Exhaust w/ 4" Tips Split Side Exit
    Chipped w/ Superchips
    Thanks so much for the quick replies, here is where it stands right now. New cap,wires, rotor and frame rail fuel filter about 7-8,000 miles back. Due to the hard starts I killed a two year old battery and now have a few week old 850 cold crank in it, my 02 sub pops of no matter what but this, now my fair weather friend is getting to me. When it is krappy out I would rather drive the 97 and leave the 02 home. What gets me is how great it runs when warm, and even gets better mileage then the 02 though it has near triple the miles on it.
    Again thanks for your thoughts on this!
    Phil
    Happy 2 Wheeler!
    Dec 2007
    Ontario, Canada
    wow, you would think the 02 would get better mileage, both have the same size engine?
    Quote Originally Posted by smainsw View Post
    The 97 is a 5.7 Vortec and the 02 is a 5.3 Flex fuel, if I am driving easy like 65 on cruise the 5.7 does better. Some of the difference may be the 97 is much lower and has stock smaller tires, the 02 is about 5 inches higher and the stock tires are quite a bit bigger. I think the older one pushes through the wind better giving me better mileage. I swapped rubber on one of my 4X4's years back to some bigger ones and lost 4 miles to a gallon, big rubber alone costs a lot more then the initial buying price.
    Phil
    Happy 2 Wheeler!
  1. 96 K1500 hard starting when engine cold
    By kcstrom in forum General Chevy & GM Tech Questions
    Last Post: 08-25-2009, 08:54 PM
  2. jimmy starting issue
    By ChevyPrincess in forum General Chevy & GM Tech Questions
    Last Post: 07-20-2009, 09:03 PM
  3. Help starting issue!
    By FireRed in forum Performance & Fuel
    Last Post: 04-06-2009, 10:22 AM
  4. Starting issue
    By ferco in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 11-13-2008, 08:29 PM
  5. Starting issue Please help
    By trivers in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 10-27-2007, 03:09 PM
