Results 1 to 2 of 2
    Newbie habbi is a glorious beacon of light
    Dec 2008
    Default 02 siverado 4.8 fuel pump
    My engine was hesitating and now won't start, no fuel pressure at test
    fitting, removed fuel pump and test on bench. In upright position it
    will not run but lay it on it's side and it will. Is this confirmation
    I need a new pump?
    Also I get no power at connector for pump in any of the 4 pins. The
    service manual says the pcm will de-energize the relay to fuel pump if
    crankshaft rotation is not detected but shouldn't there be power for a
    few seconds at the beginning? Thanks for any help.
    Jr. Apprentice hunter541 is a glorious beacon of light
    Jan 2009
    put a Gm pump in it and get it running,try to stay away from afermarket pumps there noisey and dont last and change the fuel filter [very important] as far as the power issue the only key on power is the low voltage in the purple wire the gray wire is for the pump and only last a few seconds with the key on good luck
Similar Threads
  1. Which fuel pump do I need?
    By Keats in forum Performance & Fuel
    Last Post: 05-12-2010, 01:35 AM
  2. fuel pump or....?
    By dvharris in forum Chevy C/K Truck Forum
    Last Post: 11-16-2009, 08:26 PM
  3. Fuel Pump??
    By catfish8187 in forum Performance & Fuel
    Last Post: 08-29-2009, 10:02 AM
  4. Twitching/vibrating fuel gauge - Not the fuel pump assembly.
    By Springthing in forum Audio / Video Electrical
    Last Post: 09-26-2008, 06:10 PM
  5. Fuel Gauge sender/fuel pump Together-seperate???
    By TahoeCrowe in forum General Chevy Tech Q&A
    Last Post: 09-05-2008, 03:55 PM
