Results 1 to 6 of 6
    Sr. Apprentice csmac2004 is a glorious beacon of light
    Dec 2008
    Kamloops, BC
    Question CD's stuck in CD Player!
    Hey guys,
    So I recently replaced the battery on my Yukon and now noticed that my 6-disc (factory) in dash CD player says there are no discs in it, when I know that all 6 slots are full! I'm not sure if this was happening before the battery replacement or not, but I know it was working about a month ago at least.
    It will not eject (just says there's nothing in there to eject) and yet, if you hit "Load" nothing happens. So, while it thinks its empty, it does know its full but seems to have gotten confused.
    Is there a way to reset this thing or something like that? How do I get the CD's out? Has anyone had a similar issue? Thanks!
    Scott
    2003 GMC Yukon SLT
    5.3L Flexfuel V8
    4x4
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    try disconnecting it again and see what happens otherwise leave the battery connected and pull the deck from the dash and reconnect it, or look in the owners manual for a reset of some sort, you shouldnt disconnect the battery with discs in the cd player, more often I have heard of this happening
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
    Jr. Mechanic dutzowmo is a glorious beacon of light
    Nov 2008
    Missouri
    I just have a regular cd player in my 05 silverado and it got struck and wouldn't eject. What I did was pull the dash off and pulled out the radio and unplugged it for about ten minutes. When you plug it back in the cd player should reset and spit out the cd's. I don't know if it is the same for a cd changer but it is worth a shot, worked for a regular cd player
    Legend Springthing has a reputation beyond repute
    Aug 2008
    East of Branson, Missouri
    1 Thread(s)
    Agreed. If anything, and to make it easier, may just want to unplug the battery for a while, have a hot cup of coffee, then go back and plug the battery back up.
    It just seems that electrical hiccups like that get fixed just by the battery disconnect trick. If you luck out with that then I'd shoot for the CD disconnect and reconnect.
    I've never played with stock radios/CD players too much but it seems there should be a way to manually 'pop' the disks out somehow. A switch, a reset button in the back, etc etc.
    Good luck and let us know what happens!
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
  5. #5
    Dec 2008
    Kamloops, BC
    Thanks for the responses, guys. I tried disconnecting the battery yesterday and then went to town with my brother. Coming back a couple of hours later, no go. CD's still stuck.
    So, I will try removing the player itself next when I get the truck back home where it is warmer than here at the in-laws in breezy Saskatchewan! I'll let you guys all know when I try this if it works. Otherwise, thank goodness for iPods! At least I can make new CD's of the albums I lost....
    Scott
    2003 GMC Yukon SLT
    5.3L Flexfuel V8
    4x4
  6. #6
    Newbie mlcohen is a glorious beacon of light
    Apr 2011
    Has anyone figured this one out? I have the same problem in my 04 Suburban. I tried disconnecting and reconnecting it with no luck. I pulled the unit out and took the top plate off. I can see the CDs inside but I cant get them out. There seems to be som mechanism blocking the opining. Has anyone been able to take the CD part of the unit out?
Similar Threads
  1. factory radio not playing cd's anymore.
    By 05_Z71 in forum Audio / Video Electrical
    Last Post: 04-03-2010, 07:53 PM
  2. CD player ejects CD's all the time
    By iceman68 in forum Audio / Video Electrical
    Last Post: 07-11-2009, 09:18 PM
  3. stuck in 4hi
    By dyckweed7 in forum Powertrain
    Last Post: 01-11-2009, 06:25 PM
  4. Got stuck in the mud......
    By DirtDog in forum Member Photos
    Last Post: 02-17-2008, 05:06 PM
  5. Stuck Again!
    By unplugged in forum Member Photos
    Last Post: 06-09-2007, 10:23 AM
