Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Jr. Apprentice William Young is a glorious beacon of light
    Nov 2008
    Default When To Switch To Synthetic ? ?
    I am a firm believer in synthetic oil and have used it in previous vehicles.
    The readout on my dash on the new van says I have 65% of safe oil life left before changing. I now have approx 4000 km on the vehicle.
    My monthly email diagnostic report that checks my vehicle out via satellite and checks every thing on my vehicle right down to the tire pressure in every tire, says that according to my driving conditions and habits my oil life expectancy is to 10,100 km at which time I should change it.
    Some say that synthetic should not be put in until at least 25000 km because it is such a superior lubrication over conventional oil that the rings will never seat if changed too early .
    Others say that is old hat and with the new modern engines, synthetic can be used at a much lower mileage.
    The dealer says it doesn't make much difference one way or the other as to how many miles should be on it and I was not satisfied with that response. .
    So my question is ? ? ? ?
    How many here have switched to synthetic on the first oil change and was it from good authority that prompted you to do so .
    Or should I wait until at least the second oil change ?
    W.Y.
    Sr. Engineer retired is a glorious beacon of light
    Nov 2008
    Glenside, Pa
    I don't know the km to miles conversion but here is what I've done on every new truck I've owned. First oil change 3000 miles, and filled with synthetic and changing the oil every 5000 miles after that.
    Nov 2008
    Thanks for that . I don't really believe in going 10,000 km like the computer claims it should . I have always changed oil much sooner in previous vehicles .
    I did a little conversion
    3000 miles = 4,828 km
    5000 miles = 8,046 km
    So you switched to synthetic at 3000 miles ? Seems a little soon but you no doubt have good reason for doing so.
    W.Y.
    Legend retired2001 is a glorious beacon of light
    Nov 2006
    Canyon Lake, Texas
    I know on my Winnebago M/H which has 8.1L the "book" says not to switch to "syn." until 15000 miles, so I am waiting on it, but I'd go for "after the first oil change" on the new vehicle.
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
  5. #5
    Sr. Apprentice Akula682 is a glorious beacon of light
    Dec 2007
    Niagara Falls NY
    in new vehicles it doesnt make a diff. if your OM gives you a mileage go with that if it doesnt dump it in. Some of the high end cars come with Syn Oil right off the line.
    Josh
    "Do what you can, With what you have, Where you are." TR.
    2007 Chevy 2500 6.6 LMM
    1998 HUMMER- sold
    1998 F150- sold
  6. #6
    Master Mechanic JMoney02 is a name known to all
    Oct 2008
    Brandon, FLA
    Most good engine rebuilders will state to use the break in oil first(new oil for new vehicle, actual break in oil after rebuild oil). Change at 3k miles twice, then switch to full Synthetic. Change the oil every 5k miles for your interval after that.....I have been changing oil/filter on my own since I can remember and the only problem I had was the first car I had that the intake valley was caked from oil burn. A 1970 Torino I bought from my Mom with 46k miles and QuakerState oil changes, never used it again since, that was 1975......
    Jeff
    JMoney02
  7. #7
    Jr. Engineer black jack is a glorious beacon of light
    Aug 2007
    fort myers , florida
    it doesnt matter when you change it or even miles . the chevy corvette has it from day 1. ive got an 05 pontiac gto and i changed it over less than 50 miles on od. and what a great dif in performance , on my wifes mini van i switched it over when it had 15k miles and my 05 av. i changed it over at 25k miles. it all up to you when to do it.
  8. #8
    Sr. Apprentice ChevyTech is a name known to all
    Feb 2007
    I live in New Hampshire
    I too like synth oil I use a quality synth blend instead of full however you see I am horrible at changing my oil and by horrible I mean at 2500 mile all of my vehicles get oil changed. I know I know what a waste, new oils are designed to go alot longer but it is just the routine I am stuck in and have been since I was a kid. I have worked in dealerships for the last 10 years and have heard alot of back and forth on when to go synth. As said before it doesn't matter really, I typically switch at first oil change I drive the delivery oil because I paid for it I am going to use it. The only vehicle I have that runs full synth now is my 2007 SAAB but that is because it gets it at the scheduled maintenance. My recommendation is that after 3000 miles swap out the oil for a synth of you choice, if you drive alot and are going to use the longevity of your oil than a full synth is best however if you are like me and do not drive as much and you change your oil often a good quality synth blend will be just fine I have ripped apart motors that use both and both provide good lubrication. Hope this helps.
  9. #9
    Feb 2007
  10. #10
    Former Member silveradojc is a glorious beacon of light
    Jan 2009
    motor city area
    Quote Originally Posted by black jack View Post
    I agree too, never too soon to change over
Similar Threads
  1. Switch to synthetic?
    By hoosyurdaddy in forum GM Maintenance
    Last Post: 07-08-2010, 08:20 PM
  2. Synthetic oil
    By Silverado Junkie in forum General Chevy Tech Q&A
    Last Post: 02-13-2010, 02:43 AM
  3. 1st oil chg when? chg to synthetic when?
    By LDB in forum Powertrain
    Last Post: 10-18-2009, 07:07 PM
  4. Switch to synthetic ATF on 1995 5.7L Burb?
    By jrduo4 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 07-19-2009, 02:12 AM
  5. Switch to Synthetic?
    By anthonyl9 in forum General Chevy Tech Q&A
    Last Post: 10-06-2008, 02:53 AM
