Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Sr. Apprentice PencilPro is a glorious beacon of light
    Dec 2008
    Alabama
    Unhappy Washer fluid inoperative 04' colorado!
    I have a 04 Colorado. The wiper washer fluid in not working!
    The motor isn't working so I checked the voltage and ground to it and no power but good ground.
    There are 2 relays in the wipe /wash system to operate the blades when wash is turned on. 1 is for when you turn the wipers on and the other is for when you turn the wipers on high but neither will work without the other plugged in.
    The fuse listed in the fuse box says that wipe wash is on the same fuse but doesn't indicate what relay, if there is any, operates the washer motor.
    I don't want to tear into the harness to find where it goes so--
    Does anyone have an idea where the control of the power to the washer motor comes from??
    Thanks,
    Pencil Pro
    http://www.pencilwip.com/
    Sr. Engineer retired is a glorious beacon of light
    Nov 2008
    Glenside, Pa
    Check all the fuses, GM likes to put stuff on other fuses to piss you off when things don't work.
    Sr. Apprentice oOcornflakeOo is a glorious beacon of light
    Dec 2008
    MIAMI, FL
    yeah for instance,when my radio fuse gets blown, my tach and my speedometer stop working as well. buy one of those light testers and check all the fuses like i did
    Legend tlperry68 is a glorious beacon of light
    Oct 2008
    Huntington Beach, CA
    Quote Originally Posted by oOcornflakeOo View Post
    Good idea, I should get one of those just for that reason.
    Trevor - Huntington Beach, CA
    2007 GMC 2500 4X4
  5. #5
    Dec 2008
    MIAMI, FL
    let me know if you find a bad fuse and get it working again
  6. #6
    Dec 2008
    Alabama
    Post Found it!
    I checked the fuses already and they were all good. I also swapped the relays out too and that did nothing. So I went and bought a Chiltons manual and found a schematic!
    The washer motor power is fed directly from the BCM(Body Control Module).
    The only problem with now knowing what it most likely is is finding it! There is no parts layout diagram nor does the book say where it is.
    I'm calling the Salvage yard tomorrow and in hopes that they might know and have one I can get at a cheap price. I also hope its not a common problem!
    Thanks!
    Pencil Pro
  7. #7
    Sr. Apprentice DemoMatt3 is a glorious beacon of light
    Dec 2008
    Rochester Mn area
    Body Control Module (BCM) C2 Part 1
    RIGHT KICK PANEL
    [IMG]file:///C:/DOCUME%7E1/Matt/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/Matt/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG]
    Matt
    98 Burb
    89 Burb 400K +
    91 S10 small block sleeper
    87 LeSabre 400K+
    04 Impala
  8. #8
    Dec 2008
    Alabama
    Your pix won't display on my computer.
    Seems the host for the pix is having problems.
    [quote=DemoMatt3;93335]Body Control Module (BCM) C2 Part 1
    RIGHT KICK PANEL
    I'll post my pix when I figure out how to put them here too!
    Found it by calling the Salvage yard!
    Thanks any who!
    Johnny
    04' Colorado
  9. #9
    Dec 2008
    Alabama
    Pix Attachments!
    First 2 is of the module.
    The 3rd is the input harness.
    The 4th is the putput harness.
    Attached Thumbnails Attached Thumbnails Click image for larger version
ID:	1600   Click image for larger version
ID:	1601   Click image for larger version
Name:	Input harness.jpg‎
ID:	1602   Click image for larger version
Name:	Output harness.jpg‎
    Johnny
    04' Colorado
  10. #10
    Dec 2008
    Alabama
    Thumbs up
    Tested for signal going to the module (1.5v) and for good wire to the washer motor.
    All checked good.
    Getting a new BCM when I get back from work in a month!
    Johnny
    04' Colorado
Similar Threads
  1. Washer fluid for rear window?
    By bruceb3 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 04-20-2011, 05:30 PM
  2. Washer fluid not spraying
    By 80skeys in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-30-2010, 08:08 AM
  3. frozen washer fluid lines
    By Ohio Tahoe in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 12-16-2009, 04:15 PM
  4. Windshield Washer Fluid Pump
    By meash20 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 10-08-2009, 10:34 PM
  5. Windshield Washer Fluid System
    By SilveradoBrett in forum General Chevy Tech Q&A
    Last Post: 12-08-2008, 07:34 AM
