Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Jr. Mechanic ibmoses is a splendid one to behold
    Mar 2008
    "Sweet Home Alabama"
    Default CAI recomendation for a 03 Silverado 2WD 5.3 with towing package?
    My 03 Silverado has the 5.3 with towing package, so it has the air filter indicator hickey thang...
    My question is: that scrawny looking pipe between the Throttle Body and the Air Filter Box sure looks restrictive, is there a replacement that will bolt right on and still use the factory air cleaner box?
    Forgive me for not doing research yet, I will research this but I wanted to go ahead and get some input.
    Bert
    Moderator
    dwill3015 has a reputation beyond repute
    Jan 2007
    Yacolt, Washington
    I don't think a bigger pipe is the problem with restricted airflow, its the factory air box and filter. It's better to upgrade with the whole kit to optimize airflow.
    Darcy
    Washington State
    Sr. Apprentice 04blackgmc is a glorious beacon of light
    Oct 2008
    eh its usually the piping that is the issue...Not the air box
    on my 04 i had a K&n drop in with a modded air box and Air raid intake tube and liked it.. I got a GM CAI later on and also liked it but wasnt a huge gain or anything..
    My gto just has a replacement tube with Stock airbox..works GREAT!
    OLDER:lifted 04 sierra
    OLD:2004 red m6 gto..bolt on's and cammed..
    RIP
    09 white hot G8GT premium/sport onyx/red
    1/4 13.08@106.36 60FT 1.999
    330hp 347tq
    Mar 2008
    http://marylandspeed.com/kn-fipk-int...-1-p-1913.html according to this dyno chart
    http://www.kandn.com/dynocharts/77-3021_dyno.pdf this system is pretty much worhtless in H.P. gains until way up in RPM's
    Bert
    "Race Car Spelled Backwards is Racecar"
    03 Silverado 2WD extended cab 5.3 with towing package white/silver
    70GS455
  5. #5
    Moderator
    Jan 2007
    Yacolt, Washington
    I went with a K&N FIPK kit on our Suburban which we were very happy with the gains. I installed an AFE Stage1 CAI on my Silverado, then switched back to my modded stock airbox and stock tube and got better gains than with the AFE so not always is it the Tube that is the restriction.
    Darcy
    Washington State
  6. #6
    Mar 2008
    Quote Originally Posted by dwill3015 View Post
    Thanks for the reply
    Is there a "write up" anywhere on how to "modify" or "Gut" the stock airbox?
    I was thinking all along that a drop in K & N filter and to somehow modify the stock box might be the way to go?
    My 03 2WD Silverado with towing package has the box with the indicator on it.
    I looked at Volant just now, I have not found anyDyno information on the Volant.
    Bert
    70GS455
  7. #7
    Mar 2008
    It just occurred to me:
    If these CAI's improve gas mileage then why dont the manufactures prove it.
    How hard can it be to take a brand new truck/car and put it on a chassis Dyno set the sucker on 70mph for a defined time or distance and put the cruise on while measuring the fuel consumption.
    Then repeat with the CAI or Performance "Chip", exhaust or other component.
    Perhaps this has already been done?
    Show me the DATA
    Bert
    70GS455
  8. #8
    Moderator
    Jan 2007
    Yacolt, Washington
    THE AIRBOX MOD:
    Tools:
    3" holesaw
    Small Drill bit
    Phillips screwdriver
    Dremel cut tool
    Material:
    4 SS screws
    .025 sheet of aluminum (cut out of 8"x 18" sheet)
    Shop vac filter.
    1. Remove Airbox from Vehicle
    2. Locate the side of the filter box facing the headlight assembly. In the lower left corner, remove the 3 center ribs on the outside of the box with Dremel.
    3. Drill a 3" hole into airbox between the two remaining ribs.
    4. Cut a piece out of the shop vac filter to fit area where the hole is and between the two ribs you didn't cut out.
    5. Cut the Aluminum sheet to the same size as the shop vac filter and drill a 3" hole in the middle. Try to match the hole location in airbox.
    6. Drill 4 pilot holes and attach to airbox using SS screws.
    Recommendations:
    1. Use material that won't rust.
    2. Alternate material-Corragated metal (if you can find it)
    3. Reason I chose shop vac filter? If it can keep water out of a shop vac motor, it will keep the bugs and water out of my K&N filter.
    Darcy
    Washington State
  9. #9
    Mar 2008
    Thank you sir!
    I knew there had to be a write up on this...
    I will start gathering the stuff immediately!
    Now I just have to decide what type of filter to get: K&N, AFE, Spectre, AER?
    Bert
    70GS455
  10. #10
    Mar 2008
    Duh, how does one release those two retaining pins to remove the air box?
    I wonder if a hose coud be rigged up from the 3" hole in the air box to the bottom of the front air dam.
    My truck does not have the lights in the air dam, I could cut that area out or use the hole that is already there, by removing the two hook.
    No way the hose could be 3" but it looks lile a hose for a shop vac would fab up and fit if I could find a shallow elbow to turn from the hose into the airbox...
    Thanks
    Bert
    70GS455
Similar Threads
  1. 2010 Chevy silverado 1500 Max Towing package
    By sundancer2004 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 12-11-2010, 07:34 PM
  2. Replies: 0
    Last Post: 05-25-2010, 01:00 AM
  3. Tow Package Question -- '98 Silverado
    By cqlink in forum General Chevy Tech Q&A
    Last Post: 10-18-2009, 09:32 PM
  4. How can I tell what package is in this Silverado
    By Georgethefierce in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-10-2009, 02:52 PM
  5. Towing Package
    By vaburb in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-07-2007, 10:36 AM
