Results 1 to 8 of 8
Thread: wheels1
    Newbie wheels1 is a glorious beacon of light
    Dec 2008
    Default wheels1
    radio and lights come onby themselves 98 silverado
    Legend Springthing has a reputation beyond repute
    Aug 2008
    East of Branson, Missouri
    1 Thread(s)
    You will have to elaborate a LOT on this post.
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
    Jr. Mechanic mrfixdit is a glorious beacon of light
    Dec 2008
    Gettysburg, Pa.
    We would really like to help but we're not psychic. We really need a whole lot more info like is it intermittent, is it one OR the other or does both radio and lights come on together all the time, do the lights go off if you apply the E-brake, does this happen when the keyswitch is off,were there any recent events like under dash work,electrical problems, high water etc.etc.
    Legend tlperry68 is a glorious beacon of light
    Oct 2008
    Huntington Beach, CA
    I think you need an exorcisim on the truck.
    Trevor - Huntington Beach, CA
    2007 GMC 2500 4X4
  5. #5
    Dec 2008
    lights and radio together when key is off. no in or under dash problems.no changes whith e-brake down
  6. #6
    Dec 2008
    Gettysburg, Pa.
    Looks like there may be a keyswitch problem. Do all the dash idiot lights come on too as if you turned the key on ready to start it?
  7. #7
    Dec 2008
    Default dash lights do come on
    I have been watching to see what all comes on, but everything does not always come on, we just changed the ignition switch but that did not cure the problem. we now have discovered the volt meter is dropping and the light dimming. Have also pulled all wire connections apart and cleaned(no hep) Don't know what to do at this point short of dynamite. any help appreciated
  8. #8
    Dec 2008
    Gettysburg, Pa.
    Look in your fuse panel for two little aluminum cubes they are relays one is power windows and the other accessory ( at least thats what is in my truck and I figure most GMs are very similar) try swapping them and see if your problem goes to your windows.
