Results 1 to 7 of 7
    Sr. Apprentice fx2offroad is a glorious beacon of light
    Oct 2008
    Yukon, Oklahoma
    Default Amp Remote Turn on Wire
    Ok, I'm trying to hook up the remote turn on wire for my amp. I have the oem radio which doesn't supply a remote turn on wire. I've read several post on here about running the remote turn on wire to the ignition accessory wire or the yellow dimmer wire behind the radio (which I've read that you could lose all your instrument lights if your not careful). I've spent about 2 hours trying to find a accessory wire that is only on when the car is on and i can't find one.
    Does anyone know an exact wire to use for this? I've tried everything I can think of and I'm about ready to trade in this chevy and go back to a ford ranger! errrrrrr.
    Thanks,
    Chris
    Greystone Matalic, LS
    Audio Mods: Kicker S8L7, Kenwood Amp, Pionner rear speakers
    Electronics: Viper 5701 Security/Remote Start
    Interior: 10% tent,
    Exterior: Bug Shield, OEM bed rails protectors, toolbox, tonneau cover, debadged.
    Engine Mods: Airaid Intake
    Suspension Mods: Superlift 2.5 in. lift struts, Procomp 2" add-a-leaf in the rear.
    Sr. Apprentice oOcornflakeOo is a glorious beacon of light
    Dec 2008
    MIAMI, FL
    Hmmm why would you switch back over to another vehicle over a stock radio? What makes sense to me is to spend about a $100 on a brand new radio instead of a couple $K on an old car...
    IF IT AIN'T BROKE, DON'T FIX IT
    2000 CHEVY SILVERADO 1500
    - BLACKED OUT BOW TIE
    - RHINO LINER
    - BLUE LED CLUSTER
    - SOUND SYSTEM
    - SOFT WHITE LED DOME LIGHT
    - SOON -
    - SOFT WHITE LEDs THROUGH OUT INTERIOR
    Dec 2008
    MIAMI, FL
    ... not to mention that you've driven your chevy off the lot so its probably depreciated a couple $K as well.. be rational and maybe even ask a local radio installing garage for a few pointers.. there is a site called www.the12volt.com that gives a bunch of wiring diagrams and should be able to help you out some if you know what you need and are looking for.
    - RHINO LINER
    - BLUE LED CLUSTER
    - SOUND SYSTEM
    - SOON -
    Legend Crawdaddy has a reputation beyond repute
    Feb 2007
    1 Post(s)
    Why not just go to the truck fuse panel and find a fuse that's only hot with the ignition....like the switched radio power fuse. Easy cheesy, japaneesy
    Christopher
    1991 Chevy Suburban 1/2 ton 2WD w/ chevy SBC 350-3/4 ton drivetrain upgrade w/4.10 gears 194K miles
    2005 Saturn ION-2 Stock 200K miles (In 6 years...ouch)
    1982 Bronco, 1993 Bronco, 1971 M35A2 Deuce and a Half
  5. #5
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    ignition wire, google your year truck and "factory wire diagram" and you will be set
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  6. #6
    Jr. Mechanic identityPRS is a name known to all
    Apr 2008
    Tulsa, OK
    if you go to the ignition harness, which is easily assessable, its right below the steering colum just under the dash on the drivers side, you can use either the orange, or brown wire. these are both accessory wires. just test them first. good luck!
    Cody- Tulsa, OK
    '04 silverado
  7. #7
    Oct 2008
    Yukon, Oklahoma
    Ok, well I finally got it. I bought a "add a circuit" and ended up running it off the daytime running lamps. Kind of a two for one. I can just turn it off by turning the dial or turn it back on.
    Thanks for you help!
    Interior: 10% tent,
Similar Threads
  1. Remote turn on for amp
    By kgibson181 in forum Audio / Video Electrical
    Last Post: 03-24-2010, 11:31 AM
  2. amp remote wire
    By RussellFidel in forum General Chevy Tech Q&A
    Last Post: 02-06-2010, 02:07 AM
  3. 1 wire to 3 wire o2 sensor conversion
    By L0sts0ul in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-26-2009, 11:30 PM
  4. amp turn-on wire
    By TrailFiend in forum Audio / Video Electrical
    Last Post: 12-30-2007, 10:00 PM
  5. 2003 Silverado remote wire for amp
    By mmeado in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-02-2006, 03:57 AM
