    Default 04 exteded cab windows(pop out sides)noisey
    how can i fix the exteded cab windows from whistling while driving down the road.is there a way to tighten up the pop locks?
    Legend tlperry68's Avatar
    Oct 2008
    Huntington Beach, CA
    MAtbe new weather stripping will do the trick.
    Trevor - Huntington Beach, CA
    2007 GMC 2500 4X4
    Legend unplugged's Avatar
    Sep 2006
    High Deserts of SoCal
    If you are sure that's where the noise is coming from try a little vaseline on the weatherstripping. If the noise doesn't go away look somewhere else for the trouble. The doors have weak hinges and when they sag the air comes in along the top of the door. I had it happen twice to the 06 Silverado I used to drive.
    If the noise does go away with vaseline trick, check the weatherstripping if it doesn't look worn try packing some string in the channel and reinstall it. Otherwise replace it.
    High Desert SoCal
    02 Honda Civic LX
    Default im just wanting to know
    how to tighten the locks up a bit. if i pull on the lock inward it stops
  1. Noisey 4X
    By mountaindan in forum GM Powertrain
    Last: 11-25-2009, 02:15 AM
  2. noisey nose - Front end issues
    By jffcst in forum Lifted & Offroad Suspension
    Last: 12-26-2008, 06:44 AM
  3. gaurds for the top sides of the bed?
    By erskine in forum Chevy Truck Accessories
    Last: 10-20-2008, 08:52 PM
  4. Hows This For Oppsite Sides Of The Coin!
    By crane3447 in forum The Coffee Shop ~ Chit Chat
    Last: 05-26-2008, 09:18 PM
  5. Federal judge sides with Calif. on car emissions
    Last: 12-22-2007, 08:30 PM
