Results 1 to 6 of 6
    Jr. Apprentice chazawazzle is a glorious beacon of light
    Dec 2008
    Default any quick tips on passing emmissions?
    hey guys.
    i just found out that the 1991 1500 sub that i got needs to pass emmissions. I was wondering if anyone has any quick tips to pass? it has a tbi 350 with 240000 miles but it looks like everything under the hood besides the block is bran new.
    any tips?
    thanks
    Sr. Apprentice PencilPro is a glorious beacon of light
    Dec 2008
    Alabama
    I would say take it and see what happens.
    I think that will get you a starting point.
    Johnny
    04' Colorado
    Dec 2008
    the guy said that all i need to do is to replace the gas cap and it will pass!
    Dec 2008
    Alabama
    Quote Originally Posted by chazawazzle View Post
    The smog control on your vehicle runs a pressure and vaccum (howerver you spell vaccum LOL)
    test on the fuel tank. I'm not so sure about that causing it but it is a part of the smog control.
    In 91' they didn't have a check engine light come on when it runs this test.
    I don't see that being the problem but if it was that would be a cheap fix for sure.
    Johnny
    04' Colorado
  5. #5
    Newbie gassy is a glorious beacon of light
    Jan 2009
    Most emission tests will test the gas cap with a vacuum device, replace it if it needs it. However the best is to do an oil change ( clean oil will release less stored HC into the PCV system at idle). Also a good hiway run 15-20 miles will make sure everything is hot, especially the cats and O2 sensors. Do not shut the truck off when you are in the lineup, keep it right up to temperature.
  6. #6
    Dec 2008
    Alabama
    The state I live in doesn't run an emmissions test. We only had to work on the ones that came in with the codes for it!
    Johnny
    04' Colorado
Similar Threads
  1. Tips
    By kcsilverado in forum Chevy Truck Accessories
    Last Post: 09-08-2009, 09:55 PM
  2. Exhaust tips
    By pontiacGTP123 in forum General Chevy Tech Q&A
    Last Post: 07-22-2009, 12:33 AM
  3. 86 c/30 Emmissions
    By Dashry1 in forum Chevy C/K Truck Forum
    Last Post: 05-01-2009, 01:24 PM
  4. California emmissions
    By Dashry1 in forum General Chevy Tech Q&A
    Last Post: 04-29-2009, 09:03 PM
  5. Do the 2000-2004 surburbans have passing power?
    By Enjoijoe in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-24-2009, 10:32 AM
