    Unhappy cluster backlighting out... still
    So I have my brake lights working again but I'm still without gauge lighting.. I have new LEDs waiting to be tested for the gauge backlighting but I need lighting for the cluster any ideas? all the gauges work fine except without night lights.. any help?
    IF IT AIN'T BROKE, DON'T FIX IT
    2000 CHEVY SILVERADO 1500
    - BLACKED OUT BOW TIE
    - RHINO LINER
    - BLUE LED CLUSTER
    - SOUND SYSTEM
    - SOFT WHITE LED DOME LIGHT :smile:
    - SOON -
    - SOFT WHITE LEDs THROUGH OUT INTERIOR
    Aug 2008
    East of Branson, Missouri
    CornFlake-
    I haven't been following the posts about the non-working items but in this situation here I would have to take a methodical approach to it. Do you have a manual / have access to a wiring diagram? What I would do it grab the wiring diagram, get the cluster out and take to the wiring plugs with a meter.
    Try to see if you can peg just where the problem is. If you test the plugs you could determine if you are actually getting power to the gauge when you are supposed to. At the very least it would give you a starting point as to whether the problem is in the gauge of if there's really just no power coming to it when you turn on the lights.
    Just my $.02
    Good luck with it all. I'm sure you'll get lots of helpful tips soon!
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
    I know this may sound like an obvious question, but did you check all your fuses and relays? Sometimes the aftermarket lights will blow a fuse here or there...
    I would definitley start with Springthing's suggestion with the meter, or even just a test light. If you've got an LS or LT, when you take the cluster bezel off, there should be one big harness at the very top of the cluster, you can check that too.
    Good luck!
    ok so I got an OBD-II tester and it reads, P0650 indicator lamp (MIL) control circuit malfunction.. I don't have time at the moment so I'll get back with you all about it.
    your suggestions are deeply appreciated,
    Dave
    - RHINO LINER
    - BLUE LED CLUSTER
    - SOUND SYSTEM
    - SOON -
    Master Mechanic
    Oct 2008
    Brandon, FLA
    Indicator Lamp Relay has quit working.......How is the dimmer switch also?
    Jeff
    JMoney02
    the dimmer wheel controls nothing except to turn on the dome lights when wheeled up all the way...
    - RHINO LINER
    - BLUE LED CLUSTER
    - SOUND SYSTEM
    - SOON -
    Master Mechanic TahoeFever's Avatar
    Sep 2007
    Now IN Auburn AL :)
    any luck on this issue ?
    04 Tahoe LT 5.3L stock MSD 8.5mm Wires
    Gigbson Duels Straight Exhaust, Parrot 3100 Bluetooth
    K&N 77 Series CAI, Sirius Radio
    De-badged, Valet Dei remote start
    5000k HID -Higherlevelauto.com
    Federal 100watt air horn
  1. Chevy Cluster
    By Superchevy01 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-25-2010, 09:42 PM
  2. Got a cluster question...
    By lube70 in forum General Chevy & GM Tech Questions
    Last Post: 03-14-2009, 06:17 PM
  3. Modding my cluster
    By BLUBURBAN in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-04-2009, 01:37 AM
  4. 07' Silverado cluster
    By R Dub in forum General Chevy & GM Tech Questions
    Last Post: 02-26-2009, 05:39 PM
  5. 99 Suburban factory stero backlighting
    By Jenks99sub in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-22-2007, 09:41 AM
