Results 1 to 7 of 7
    Newbie SFSUBURBAN is a glorious beacon of light
    Jan 2009
    Default Suburban Misfire Woe's
    Hello, I have a 96 Suburban with a 5.7 Vortec Motor.I test drove it before I bought it throughly and it seemed to run like a champ.However, It had a misfire on cylinder 4 code the day after I purchased it when I drove it. I decided to do a tune since I recently purchased this truck. I changed the plugs,cap,rotor,wires and fuel filter. The truck idles fine and seems to have power, however I started to get a Random Misfire Code. I checked the wires,cap and rotor and since they were under warranty I replaced them. Now I keep getting a P1345 CMP/CPK Corrolation code. I swapped out the crank sensor to 2 other one's and reset the ECU with my scanner and I keep getting the same code....P1345. Help. What else can I do/check?
    Please help any advice will be helpful
    Also there's a little wire with some sort of plug or clamp deal on the end of it. It is located under the Intake manifold/box right next to a square wire plug next to the TB. What does this go to...is it supposed to be connected to anything?
    Jr. Mechanic mrfixdit is a glorious beacon of light
    Dec 2008
    Gettysburg, Pa.
    Check your timing if your distributor is advanced too far the cam sensor won't agree with the crank sensor
    Jan 2009
    I used my scanner to monitor the motor....it says the timing to be -27 degrees and when you press the gas it moves to -18 or so when driving. I did notice that the rotor seems to have a some clockwise/counter clockwise play meaning I can move it back and forth by hand. I do not know if this is normal since this is my first American car in like15 years. On my Honda it's firm I cannot move it.
    Legend MrShorty has much to be proud of
    Jan 2006
    Utah
    The correct parameter for checking timing is the cam sensor retard, which is only read by the more expensive scanners. Spec is +/- 2 degrees or something like that.
    I'm not sure how much play there should be in the rotor, but I know I've seen many report problem with the distributor gear.
    '98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
    '92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
    "My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
  5. #5
    Jan 2009
    Thanks for the reply. Is there a fix for the gear/play on the rotor. What about the pigtail that is near the TB.Does that go to anything?
  6. #6
    Jan 2006
    Utah
    If the distributor gear is worn, then replace the distributor gear.
  7. #7
    Jan 2009
    Well I took it to a guy that works at a Chevy dealer. He determined that it was off on the timing. He pulled the Dist. since he believed it to be off by atleast 1 tooth. He moved it and adjusted the timing with the TEC2 deal..I guess we will have to see. So far no hicup's and CEL or in this case SEL. Thanks for the input guys. I will be around lurking, learning and asking questions.
Similar Threads
  1. still have misfire help please
    By cable734 in forum Powertrain
    Last Post: 05-16-2011, 09:39 AM
  2. Misfire
    By OkieMike in forum Powertrain
    Last Post: 03-04-2008, 07:43 AM
  3. Misfire
    By KingDNH in forum Powertrain
    Last Post: 02-13-2008, 03:23 PM
  4. 99 GMC Yukon- Distributor and Rotor Woe's
    By GWAGON_99 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-20-2007, 12:10 PM
