Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Sr. Apprentice Eclipse is a glorious beacon of light
    Jun 2008
    West Texas
    Default will it work ?
    08 silverado crew cab 5.3 , replacing my 6.5s and adding 2 subs, powering it up with 2 amps, together they making about 900 watts rms, will my truck power it up fine or do i need to upgrade anything or mod anything?
    Also i noticed that at night when my lights are on if i mess with my windows my headlights seem to dim very slighty or maybe even flicker barley noticable but i do notice it when i watch for it? is that normal and does that mean anything as far as needing to upgrade before i add 2 amps?
    08 Silverado 5.3
    - Custom true dual exhaust w/ Flowmaster 50 series mufflers, X - piped, dumped
    - Sound - 2-12" Infinity subs,2-pairs Infinity 6.5 components, 2-amps Infinty 4 channel/Infinity mono, subthump box w/ SILVERADO text
    - Recon 60" whitelighting L.E.D. brakelight bar
    08 Jeep Commander 4.7 - stock for now
    Legend Crawdaddy has a reputation beyond repute
    Feb 2007
    1 Post(s)
    You SHOULD be able to support those subs just fine with the stock alternator and amp. The windows causing the lights to dim is normal. The window motors pull a good bit of current when they operating, particularly when they stall (like when you hit bottom or top of the window travel. In my car I can watch a 2 volt drop when I move the window at all.
    Christopher
    1991 Chevy Suburban 1/2 ton 2WD w/ chevy SBC 350-3/4 ton drivetrain upgrade w/4.10 gears 194K miles
    2005 Saturn ION-2 Stock 200K miles (In 6 years...ouch)
    1982 Bronco, 1993 Bronco, 1971 M35A2 Deuce and a Half
    Sr. Apprentice goodie is a glorious beacon of light
    Jan 2009
    Midland, Tx
    dont trust me or what bryan
    if it is a problem the "Big 3" is an easy way to get a little more power out of your charging system
    Jr. Mechanic TMRuiz is a glorious beacon of light
    Dec 2008
    Gonzales, Louisiana
    If you are worried about your lights going dim when you put the screws to the volume you can always get a capacitor (most likley from the same place you got your amps) install it inline between the battery and the fuse on the main powercord feeding your amps. This should eliminate that light flicker just from the power drain of the amps. Like Crawdaddy said thats normal for your lights to do that with the windows and you can even see that with the stock stereo at night if your sitting at a stop light and you have the tunes really cranked. But since you will using the amps to power the stereo the capacitor will take care of that. It's not neccessary but it does help.
  5. #5
    Jan 2009
    Midland, Tx
    it doesnt really matter if the cap is before or after the fuse, but if your going to get a cap you might as well just get a quality second battery instead...much more affective (since caps do more harm then good in most cases) and also it is cheaper
    and like i told you today i got that battery you can have for tha cheap if we can make her fit under the hood: http://www.odysseybatteries.com/battery/pc2150.htm
  6. #6
    Sr. Apprentice jprimrose4292 is a glorious beacon of light
    Jan 2009
    Vancouver, WA
    If your running about 900 watts(1 farad for every 1000watts) you should get a power cap and locate it as close to the amp or amps as possible depending on the setup or whatever is pushing the subs.
  7. #7
    Jun 2008
    West Texas
    Thanks for all the replies(whew glad the window thing is normal, yeah thats where i see it is at top or bottom of travel), ah Goodie , glad to see you on here, can't wait to get some mods going on that GMC of yours. yeah well have to check out that battery, although u might need it if u go with any of your setups like in the past in your new truck!
    08 Silverado 5.3
  8. #8
    Sr. Apprentice skoal bandit is a glorious beacon of light
    Nov 2008
    Gonzales, Louisiana
    I agree with GOODIE. A battery might be the best thing, after all, there is a nice spot on the 08s to put a second battery. If yours is like mine, your battery is on the passenger side in a bad spot underneath a brace. On the drivers side behind the headlight, there is a perfect spot to put another battery.
    Skoal_Bandit
    -2008 Silverado LT1 Crew Cab 5.3/6.2L swap
    Circle D 3000, CAI, 222/230 EPS cam, Patriot Dual Springs,
    LTs, Magnaflow, 2/3 drop
    -Best 1/8 8.5 @ 82 on stock 20s
  9. #9
    Jan 2009
    Vancouver, WA
    A second battery is for when you want to run assessories for extended periods of time with the engine off. A cap will help with the extra power draw for the windows.
  10. #10
    Jr. Mechanic StillMatic is a glorious beacon of light
    Dec 2008
    Sharon Hill, PA.
    Quote Originally Posted by jprimrose4292 View Post
    Correct, but he said 900 watts rms! Thats not the total wattage. His total wattage has to be at least 1500 to 1800 watts. When using amps, go by the total watts to determine what cap you need. If I were yo, i'd get a 2 Farad cap and call it a day.
    1997 GMC Suburban
    22 inch Ice Metal Rims
    170k and still truckin'
Similar Threads
  1. Replies: 0
    Last Post: 07-27-2010, 10:20 PM
  2. Replies: 0
    Last Post: 07-14-2010, 08:40 PM
  3. Replies: 0
    Last Post: 06-24-2010, 06:30 AM
  4. Battery Died, Gauges work/no work
    By Chris_N_Kris in forum General Chevy Tech Q&A
    Last Post: 02-26-2010, 10:54 AM
  5. Replies: 0
    Last Post: 07-20-2009, 12:20 PM
