Results 1 to 6 of 6
    Jr. Apprentice jcook90 is a glorious beacon of light
    Jan 2009
    NY
    Default New here - LED taillight bar problem
    Hey guys, first post here.
    I have a 2004 Silverado ext. cab and today I installed a Plasmaglow rear LED light bar. I have the 7 pin trailer light plug, but the light bar uses a 4-pin. Before I actually hardwired the bar into the back of the 7-pin, I checked to see if the LED's worked (with the 7 to 4 pin adaptor). The problem I noticed was when I would turn on either indicator light, it won't blink. The normal indicator bulb will light up and the bar will dim, but no flash. Anyone have similar problems or know what could be the problem?
    2004 Silverado Z-71 Ext. Cab
    Volant CAI
    Flowmaster american thunder dual exhaust
    Legend Springthing has a reputation beyond repute
    Aug 2008
    East of Branson, Missouri
    1 Thread(s)
    Sounds like a cross in wires, faulty trailer wires, or faulty LED bar. I would get a meter to double check your trailer pins to make sure you are hitting the right ones. If you are and your meter jumps at the appropriate times when the proper turn signal is on I would contact Plasmaglow and ask them what to do. That's the only idea I have. Hopefully someone else will have a thought and/or have had the same problem.
    Good luck,
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
    Legend 04sierracrewcab is a glorious beacon of light
    Aug 2008
    Deer Park Texas
    Quote Originally Posted by Springthing View Post
    Good luck,
    I agree!
    Welcome to the site!
    Ryan
    2002 Jeep Wrangler Sport 4x4 (the Yellow Jacket)
    4inch suspension 3inch body
    Straight 6 (383 Stroker within a year)
    36inch SuperSwamper TSL.
    105,000
    Detroit Loccers
    Daily Driver Weekend Wheeler
    much more...
    2004 Sierra crew cab, 2wd, 5.3 V8
    2inch Daystar Leveling kit
    single dumped Flowmaster 40 sieries exaust(removed)
    Mb Blitz Chrome wheels
    Leer Bed Cover(for sale)
    50k miles
    Legend tlperry68 is a glorious beacon of light
    Oct 2008
    Huntington Beach, CA
    Does your new taillight bar have the turn signal, not all do. Make sure it is supposed to have that function as well.
    Trevor - Huntington Beach, CA
    2007 GMC 2500 4X4
  5. #5
    Jan 2009
    NY
    Well I went out and "messed" around with some of the wiring to see what would happen. Without the running light wire connected, the turn signals would work, except when the brake was depressed. The brakes would come on as well. I finally left it with just the running and reverse lights hooked up so I could drive and have functioning turn signals.
    http://www.plasmaglow.com/catalog/pr...products_id=59
    That's the bar I bought, so it does have turn signals.
    Volant CAI
  6. #6
    Master Mechanic JMoney02 is a name known to all
    Oct 2008
    Brandon, FLA
    it does sound as if your wires are not on the correct connections, did they give a good diagram? Why are you not using the 4 pin connector in the harness, instead of the 7 pin? Should be attached up on the drivers side I believe with the coonector already attached! These are suppose to be wired with bot the coonectors so you can choose what lights you want to run for what trailer your pulling.
    Jeff
    JMoney02
Similar Threads
  1. LED Taillight Problems
    By ИorτнRoαdΛĸ907 in forum Audio / Video Electrical
    Last Post: 08-24-2010, 02:45 AM
  2. LED taillight bars...
    By meash20 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-15-2009, 07:56 PM
  3. taillight
    By blacksilverado07 in forum Chevy Truck Accessories
    Last Post: 03-09-2008, 10:09 PM
  4. 88-99 taillight
    By DaryleC in forum For Sale & Wanted to Buy
    Last Post: 01-28-2008, 11:44 AM
  5. Taillight covers
    By bartramparke in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 03-30-2006, 11:19 PM
