Results 1 to 4 of 4
    Sr. Apprentice heaviechevie is a glorious beacon of light
    Oct 2008
    Northeastern Pa
    Default Need some Info ....
    My first question is I have a really good deal on a 383 stroker motor (needs valve guide seals on one cylinder) with resonable mileage and it hasn't been beat. A friend of mines uncle just bought a new stroker motor and put it in his 84 K10 and is willing to sell me the other motor at a fraction of what it costs. My question is at about 400 hp should I invest in a 350 or 400 trans (currently I have the 700r4 in mine) and what about a stahl converter? Also if I change the tranny do I need to lengthen my drive shaft and will my transfer case work on the other 2 trannys?
    Second (I guess it's actually third) I did get my carb working semi correctly, I haven't had to many little problems but unlike most holley 1850-2 carbs mine has the choke fresh air inake hose drilled. Do I need to plug this or should a vacuum line be hooked up to somewhere else to it? The truck doesn't run to bad with it open but it does seem to get a rough idle (more of a surging that you can see with the alt. gauage bouncing below 12 v) but it def. has more power than before. Any sugestions on whether to plug, run a vacuum line somewhere or just let it open?
    Michael Sharar
    Sr. Engineer retired is a glorious beacon of light
    Nov 2008
    Glenside, Pa
    Ok I think that your 383 probably isn't as worked as you think it is. It is probably more like 300hp. A nice performance built 700 4R is perfect for your set up. Secondly your carb is to big for that motor. But this is just my opinion.
    Oct 2008
    Northeastern Pa
    It's a zz383 crate motor (425hp, 449 ft-lbs torque). My current motor is just a 350 with some aftermarket parts but the carb I have on it is a Holley 1850-2 (4160 series, 600 cfm, vacuum secondaries) smaller than the Q-jet that it replaced. The 383 comes with an Edelbrock carb so the Holley isn't going to be used. I just need to have the current motor running decent till spring when I can have some nice days to do the swap. I also don't want to run into the same problem that I had when I put a performance 350 (had 300 hp) in a blazer that I had and blew the stock torque converter up.
    Michael Sharar
    Nov 2008
    Glenside, Pa
    700 R4 trans can handle your HP. If the converter is an issue, buy a quality converter.
Similar Threads
  1. Need info please
    By cobra2end in forum General Chevy Tech Q&A
    Last Post: 03-12-2010, 11:10 PM
  2. Any Info
    By yammaharider114 in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 08-12-2009, 01:32 AM
  3. I like these any info though...
    By vncj96 in forum Lifted & Offroad Suspension
    Last Post: 03-22-2009, 07:53 PM
  4. Need Some Info
    By Blackmatter in forum Audio / Video Electrical
    Last Post: 03-10-2009, 11:30 PM
  5. Would like info.
    By llstuber in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-21-2007, 01:37 AM
