Results 1 to 2 of 2
    Newbie wwadefarm is a glorious beacon of light
    Jan 2009
    Default 99 K2500 fuel gauge
    I have a 99 Chevy K2500 classic p/u. When the fuel tanks reaches @ 1/2 full the gauge starts bouncing and gets worse the lower the tank gets. What could this be and how to fix? I have heard the sending unit is part of the pump and is in the tank and is expensive, but I found a sending unit on line that doesn't have the pump withit for @ $60.Before I order just wanted to make sure.
    Newbie Kerchak is a glorious beacon of light
    Jan 2009
    I've got a '99 1500 that had the same issue. I obtained a used sending unit from a friend, but ended up replacing the fuel pump (which came with a sending unit) to the tune of about $300. Spendy, but it worked.
Similar Threads
  1. Fuel Gauge
    By jnbascom in forum General Chevy Tech Q&A
    Last Post: 06-06-2010, 08:08 PM
  2. Twitching/vibrating fuel gauge - Not the fuel pump assembly.
    By Springthing in forum Audio / Video Electrical
    Last Post: 09-26-2008, 06:10 PM
  3. Fuel Gauge sender/fuel pump Together-seperate???
    By TahoeCrowe in forum General Chevy Tech Q&A
    Last Post: 09-05-2008, 03:55 PM
  4. 98 K2500 fuel pump question.
    By KnightRider in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-21-2008, 07:00 PM
  5. fuel gauge [Expired Topic]
    By ben_mtl in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-09-2007, 10:53 PM
