Results 1 to 7 of 7
    Jr. Apprentice mankan is a glorious beacon of light
    Jan 2009
    Vänge -Sweden
    Default Speedometer dead after wire clean out
    Hi
    I have a -88 ck1500 stepside thet i changed the motor in.
    I took out the tpi engine and put in a 383 stroker with a 8v-71 supercharger
    When i installed the engine i cleand out all of the wires that hd anything to do with the injection.
    Now everything but the speedo does work.
    Any ide`s
    Thanks
    /M
    Attached Thumbnails Attached Thumbnails Click image for larger version
    Legend Crawdaddy has a reputation beyond repute
    Feb 2007
    1 Post(s)
    by 88 the truck should have had a fuel injected engine with a 700R4 behind it. That 700R4 had a speedo sensor in the tailshaft section that fed converter which then fed the speedo, transmission, cruise control and computer a speed signal. If you hacked out anything in between, you have your issue as to why it's not working. So, you either have to replace/repair the wiring, or you could possibly pull an instrument cluster out of the same bodystyle truck, but older that had a manual speedo cable and retrofit all the associated parts into the transmission and such.
    Christopher
    1991 Chevy Suburban 1/2 ton 2WD w/ chevy SBC 350-3/4 ton drivetrain upgrade w/4.10 gears 194K miles
    2005 Saturn ION-2 Stock 200K miles (In 6 years...ouch)
    1982 Bronco, 1993 Bronco, 1971 M35A2 Deuce and a Half
    Jan 2009
    Vänge -Sweden
    Quote Originally Posted by Crawdaddy View Post
    Hi again
    I might have cut out a grounding point some where.
    There was a ground that was on the thernostat house that i cut away
    I think that might be the problem
    I have not cut anything under the car exept for the wires to the gas tank.
    I took it away and put a fuelcell on the bed . There it´s a ground wire in that connector but i think that´s for the fuelpump and gasoline meter i have a mec pump on the engine now so i dont use those
    /M
    Master Mechanic JMoney02 is a name known to all
    Oct 2008
    Brandon, FLA
    Yes that true, but Crawdaddy's right, your probably going to need to return to the old style cable, unless you still have the 700R4 in it, then you will need to step it as it was, with the missing ground from the Thermostat, as that was a part the of the cluster, ignorant as GM can be sometimes...
    Jeff
    JMoney02
  5. #5
    Jan 2009
    Vänge -Sweden
    i still have the th700 in the car
    Thanks for the answers
    /M
  6. #6
    Oct 2008
    Brandon, FLA
    Quote Originally Posted by mankan View Post
    /M
    You welcome, looks like a beast, what is the outcome to be for this truck, show, go,racer, daily driver(right) some of the above or none of the above? Has a good start...
    Jeff
    JMoney02
  7. #7
    Jan 2009
    Vänge -Sweden
    Quote Originally Posted by JMoney02 View Post
    Jeff
    Hi
    Well i dont realy know what it will end up like.
    Im gona narrow the rear end and put in a nerrowed(?) rear axel. And its going down about 4´´ all around
    The reason i bought a 4 wd is that in sweden wi have a rule that says that if the car weights more than 2500kg in stock and is 88 or older we dont have any pullotion rules.So mayby i will take all of he frontdrive stuff away , i realy dont know yet.Its going for inspetion next week so i will have to take the blowe of and then put it back after the inspection
    So its gona look a bit like a prostreet but shall be just a fun driver
Similar Threads
  1. Speedometer
    By TheShamrock7 in forum General Chevy Tech Q&A
    Last Post: 01-05-2010, 09:13 PM
  2. 1 wire to 3 wire o2 sensor conversion
    By L0sts0ul in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-26-2009, 11:30 PM
  3. Speedometer
    By EagleTalons in forum Chevy C/K Truck Forum
    Last Post: 12-13-2008, 03:07 PM
  4. speedometer off
    By sierraman in forum Audio / Video Electrical
    Last Post: 02-22-2008, 08:06 PM
  5. speedometer
    By chevydude in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 12-27-2006, 08:07 PM
