New to the site....great info.
I have a problem with my 1988 silverado 5.7
I recently did a tune up on it including: plugs, wire, cap, rotor, and fuel filter.
I made the bone head mistake and twisted the steel braided fuel line when I put the fuel filter on. Then when I started it, of course with out knowingwhat I had done, it ran like crap. I replaced the fuel line and started it up. The truck ran awsome for aobut 5 min. After that is chugged and died. Started it back up and it started but I have to keep the gas pushed otherwise it dies. It seems to run great as long as the gas is pressed, otherwise it dies
What i have done:
replaced the fuel filter...again
checked the fireing order
taken apart and cleaned the throttle body
What I think it could be
fuel pump
fuel preasure regulator
Hopefully someone can help
Thanks in advance
Jon
Welcome to the site!
How many miles are on the pickup?
Ryan
2002 Jeep Wrangler Sport 4x4 (the Yellow Jacket)
4inch suspension 3inch body
Straight 6 (383 Stroker within a year)
36inch SuperSwamper TSL.
105,000
Detroit Loccers
Daily Driver Weekend Wheeler
much more...
2004 Sierra crew cab, 2wd, 5.3 V8
2inch Daystar Leveling kit
single dumped Flowmaster 40 sieries exaust(removed)
Mb Blitz Chrome wheels
Leer Bed Cover(for sale)
50k miles
I'm guessing that it is a fuel pressure problem. You may have done damage to something from backing up the fuel flow (I'm thinking pump). Good luck.
Thanks
The od says 251,000 but I am pretty sure that the motor has been replaced seems how I dont think that the truck came stock with steel braided fuel lines.
One thing I did notice is that after 5 min the fuel begins to spudder out of the injectors.
One thing that I diont understand is that if I keep my foot on the pedal right above idle, it runs great. Its only when I try to let it idle is when I have the problem. If it was the fuel pump, would that happen? Seems more like the preasure regulator would cause this result, anyone know?
Bookmarks
