GM Truck Club
Page 5 of 7 FirstFirst ... 34567 Last Post byLast Post by
Results 41 to 50 of 68
  1. #41
    ok. i'll try it and i'll let you know how it goes!
  2. #42
    Master Mechanic bigdaddy77084's Avatar
    Jan 2010
    Houston, Texas, United States
    Is this good for my year Hoe??
    Quote Originally Posted by dwill3015 View Post
    Intermediate Steering Shaft Lube Procedure
    cures knocking felt through steering wheel
    reference GM bulletin #00-02-30-003C
    Tools Needed:
    needle nose pliers
    15 mm wrench
    GM kit #26098419
    You can find it here www.gmprtsclub.com
    Step 1: Start with the front wheels straight ahead and the column locked, if equipped. Remove nut with 15 mm wrench at steering shaft under dash.
    Step 2: Disconnect shaft by pushing towards firewall.
    Step 3: Remove bolt on steering shaft under the hood.
    To be continued...
    95 tahoe 2dr 4x4 200,000+ miles
  3. #43
    Legend
    murdog94's Avatar
    Feb 2008
    Cloquet, Minnesota, United States
    I dont think so...
    Mike
    Currently
    1997 Chevy S-10 Blazer 4X4 with 330K miles and counting (Hunting rig).
    2009 Saturn Aura XE (wifes car)
    2011 F-150 Crew 4X4
    "Hold it to the floor till you see God.... Then Brake!!!!"
  4. #44
    Ya me either, i think the issue starts around 2000 in some models and bu 03 almost every model lol
    Besides, my last truck was a 93 2500extcab 4x4, 380,000 on it when i retired it and no steering shaft noises.
    Your truck does not have the intermediate shaft. if it did, i would do the grease fitting fix. Read up here a bit.
    2004 Chevy Silverado Z71, 5.3L auto
    Beginning work in progress
  5. #45
    Default 2007 Yukon
    Quote Originally Posted by skinner View Post
    And the updated design is a piece of s**t as well, a few of our members have found out very quickly.
    There is no known replacement component to repair this issue to the best of anyones knowledge as far as i can tell.
    Try the mod that i posted earlier in this thread, everyone who tried it so far is happy, and thats almost everyone here i think.
    There are 2 repair options in this thread, post# 1 shows disassembly and regrease, and my post shows a mod to grease it externally, use which ever one yoou wish, both will work, it seems mne works more permanently.
    Hi I was just wondering where i could find the pics of your fix externally.
    I have a 2007 Yukon and its very hard to steer when going slow or backing up.
  6. #46
    Very good write up. I have a 2004 Silvarado crewcab Z71 at 60,000 miles the steering wheel started clunking during slow speed turns. I pulled the intermediate steering shaft out and installed a grease zerk and plugged the bottom of the shaft. Video of the procedure is on Youtube. I installed a rubber stopper between the zerk and bolt to hold the grease in the steering shaft. Once it was put back on the truck and pumped full of grease the steering is like new again and now I have access to pump more grease in as needed. The repair cost me about $35 including the 15mm wrenches to take the truck apart. I have some mechanical background but anyone can do this.
  7. #47
    Quote Originally Posted by mowrfixit View Post
    It is post #20 in this read, second page i think, skinner
  8. #48
    Sr. Apprentice
    Feb 2009
    FT. Wayne, IN
    Just wanted to give a little update... I replaced my intermediate shaft with gm's updated part a year ago. So far it is still working like new 15k mi later!
    2003 Silverado LS 1500 Xcab 5.3 vortec 3.73 rear.
    2000 Artic White Buick Regal GS, 3.4 pulley, 3"dp, 13.81 @ 101 (sold)
    2002 Z28 Camaro, 1sc, a4, slp lid, headers, cb exhaust, 3.73
  9. #49
    Newbie
    May 2011
    Schreiber Ontario Canada
    Thanks for the info. I replaced my intermediate shaft but was reluctant at first until this thread showed how easy it was to remove and replace it. done in 20 minutes. thanks again
  10. #50
    Default Steering Shaft Quick Repair
    Nice write up, a quick fix for the knock is to just take that 15mm nut and bolt loose under the hood and disconnect the shaft from under the hood only. Next pump the shaft up and down about 15 times to redistribute the grease that is already in the shaft, then reconnect the shaft and install the nut and bolt. This is a temporary but quick repair. Rock on!!
Similar Threads
  1. Intermediate Steering Shaft
    By Big_Ben in forum General Chevy & GM Tech Questions
    Last: 03-29-2010, 01:15 AM
  2. So I Changed My Intermediate Steering Shaft. But....
    By Alaskan in forum Chevy Silverado Forum (GMC Sierra)
    Last: 12-15-2009, 10:47 PM
  3. Intermediate Steering Shaft
    By ukrkoz in forum Chevy Silverado Forum (GMC Sierra)
    Last: 07-01-2007, 01:42 PM
  4. Intermediate steering shaft
    By shaman6 in forum Announcements & Feedback
    Last: 03-17-2007, 09:21 AM
  5. Intermediate steering shaft
    By shaman6 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 10-02-2006, 07:17 PM
