Page 1 of 7 123 ... Last Post byLast Post by
Results 1 to 10 of 68
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    Default Intermediate Steering Shaft Lube Procedure
    cures knocking felt through steering wheel
    reference GM bulletin #00-02-30-003C
    Tools Needed:
    needle nose pliers
    15 mm wrench
    GM kit #26098419
    You can find it here www.gmpartsclub.com
    Step 1: Start with the front wheels straight ahead and the column locked, if equipped. Remove nut with 15 mm wrench at steering shaft under dash.
    Step 2: Disconnect shaft by pushing towards firewall.
    Step 3: Remove bolt on steering shaft under the hood.
    To be continued...
    Darcy
    Washington State
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    Default ISS Lube Procedure Part 2
    Step 4: Disconnect shaft and push towards firewall.
    Step 5: Pull shaft out from inside cab.
    Note: The procedure to lube the shaft is described, in detail, in the instructions that come with the kit.
    Step 6: Remove the spacer with needle nose pliers.
    Step 7: Squirt all the grease from the kit into the end of the shaft, try not to get any on the sides at the top or it will be hard to keep the stopper from slipping out under pressure.
    Step 8: After installing the stopper into the end of the shaft, place the u-joint at 90 deg. and press against a hard surface.
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    Default ISS Lube Procedure Part 3
    Step 9: Pull the shaft out to full travel and make sure there is at least 1/2" of grease protruding.
    Step 10: Spread the spacer out a little with snapring pliers or by carefully pulling your needle nose pliers.
    Step 11: Tap the spacer into the end of the shaft untill it is 1/4" from the end.
    Step 12: Reinstall the shaft by pushing it back through the hole from the cab. Tighten the upper nut to 35 lb ft and the lower bolt to 37 lb ft.
    good write up.... was this a dealer part or an aftermarket one? and how much was it?
    2004 chevy silverado "northwest edition" lifted on 35's
    1990 cherokee lifted on 32's
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    Not my work. I have seen this on other sites so i wanted to post it here to be helpful. Mine has been replaced once under warranty but for those that have no choice but to do it themselves, here is how.
    Quote Originally Posted by dwill3015 View Post
    Thanks for the post. I have to do this on my truck. Know I know what to do
    2004 Silverado Z71, K&N cold air intake, mbrp catback w/dual tailpipes and 3" stainless tips
    Thanks for that!
    Master Mechanic
    Oct 2008
    Brandon, FLA
    Excellent Darcy, just was reading about replacement parts. haven't purchased it yet but will try this first. Even though I do not have the clunck yet, I also read some were that this was available, Thanks for bring this back up again....
    Jeff
    JMoney02
    if you are out of warrenty it will cost about 250.00 to replace the shaft my servesing dealer told me that the grease repair is a temp fix and will have to be redone within a year..that is why he is only doing replacements unless the person insists on the grease repair out of warrenty as well as under warrenty
    Dan
    2006 GMC 1500 Long Bed Vortec 4.3
    1982 S-10 Prodject Street/Track with a 327/300hp Motor built up to 415 hp
    if anyone wants i can get this part for probably around 100 dollars. I have a buddy that works at hummer they have had the same problem and had a replacement to fix the problem. He got me mine Ii would be willing to part with it. I am selling my tahoe and it doesnt make the noise anymore. I will send a pic of the part i have to whoever wants it just so you know you are getting the right one. there are two differant ones.
    2008 Chevy Silverado WT for sale
    All black with DJM 4/7 drop sold
    Factory Navi for sale
    22inch Escalade wheels sold
  1. Intermediate Steering Shaft
    By Big_Ben in forum General Chevy & GM Tech Questions
    Last: 03-29-2010, 01:15 AM
  2. So I Changed My Intermediate Steering Shaft. But....
    By Alaskan in forum Chevy Silverado Forum (GMC Sierra)
    Last: 12-15-2009, 10:47 PM
  3. Intermediate Steering Shaft
    By ukrkoz in forum Chevy Silverado Forum (GMC Sierra)
    Last: 07-01-2007, 01:42 PM
  4. Intermediate steering shaft
    By shaman6 in forum Announcements & Feedback
    Last: 03-17-2007, 09:21 AM
  5. Intermediate steering shaft
    By shaman6 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 10-02-2006, 07:17 PM
