Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Newbie Elbutcho is a glorious beacon of light
    Jan 2009
    Question Truck has no Power
    I have a 1998 Chevy 1500 truck, when I start it up it runs fine but after it gets a warmed up it loses almost all torque, it also does this under a load. It spurts and misses when given small amount of gas too. I replaced the O2 sensors and fuel filter but that didn't fix the problem. Do you think changing wires, plugs, rottor, and distributor cap will help???
    Thanks
    Moderator
    GaryL is a glorious beacon of light
    Mar 2006
    The Colony, Tx
    It could be a tune up issue but it could also be a fuel pump problem. Check your fuel pressure and make sure you have at least 62 psi. If it is lower than that, it will need to be replaced. My Suburban went through this this past summer.
    Gary
    99 K 1500 Suburban
    78 Silverado Big 10 w/factory 454
    1977 Formula
    1976 Trans Am
    1980 Honda CB900 Custom
    Jan 2009
    Quote Originally Posted by GaryL View Post
    Thanks...................how hard is it to replace a fuel pump if that's the problem???
    Jr. Engineer werty is a glorious beacon of light
    Jun 2008
    romperland
    ive seen junk cats do something like this before also....
  5. #5
    Jan 2009
    Quote Originally Posted by werty View Post
    Huh???
  6. #6
    Jun 2008
    romperland
    i had a buick 3.8 that the catylic convertor went to **** and ran good eveytime until it heated up the cat would plug and glow red...
  7. #7
    Jun 2008
    romperland
    i guess i got censored....sorry
  8. #8
    Jan 2009
    Someone told me today that may be the problem........said I can check it with one of those infra-red temperature measurement sensors to see if the temp is hotter before the converter.
  9. #9
    Jr. Engineer mjalstad is a glorious beacon of light
    Jan 2009
    Rochester, MN
    I've heard of the older Fords having a problem with the ignition module when they when get warmed up. If you haven't done a tune up in a while you may want to start there. Otherwise could this be a MAF problem? You could try driving it till it starts having problems, then unplug the MAF sensor and see if it runs better. As long as you don't have major engine modifications, it should run ok with the MAF unplugged. Changing the fuel pump is not that much fun and would probably take a few hours to replace.
  10. #10
    Master Mechanic CarpenterGuy is a glorious beacon of light
    Jul 2008
    Leeds, Alabama
    that same thing happened to me and it was my fuel pump.
    2006 Silverado Z71 - 97,000 - totaled, RIP
    2006 Silverado Z71 - 70,000 (K&N 77 Series CAI, PowerAid TBS, Magnaflow dual rear exit, 33x12.50 Mickey Thompson MTZ, Tuff Country Torsion Keys, Tuff Country Add-A-Leafs)
    I'll keep my money, guns, and freedom. You keep the Change.
Similar Threads
  1. Power windows and locks from 08 Sierra to 06 Work Truck?
    By pearsons in forum General Chevy Tech Q&A
    Last Post: 07-07-2010, 10:23 PM
  2. VHTF Power Wheels Silverado truck hood parts
    By Steve in forum Chevy Parts eBay
    Last Post: 07-02-2010, 10:00 PM
  3. Power Wheels Chevy Silverado truck hood part
    Last Post: 06-15-2010, 08:30 AM
  4. 94 Power Locks on a Non Power Truck?
    By kuziwr in forum Audio / Video Electrical
    Last Post: 11-12-2009, 09:37 PM
  5. turning off accessory power outlets when truck is not running
    By etpn13 in forum Audio / Video Electrical
    Last Post: 05-24-2009, 07:04 PM
